• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
1
Photoshop freeze-up when editing a text box
Community Beginner ,
Jan 30, 2017 Jan 30, 2017
I had enough. I can't understand why and what's the context when this is happening. Only thing I know is that I select the type tool, enter in edit mode and usually I hit escape key because I just wanted to see the font size, line height and so on. But from time to time, when I hit the escape key, nothing happens and that means that everything I'll do from that point nothing will happen. The text box remains active but I can't do anything to Photoshop. Even if in the first 10 seconds I can select other tools, nothing happens.
The only solution is to kill the process from Activity Monitor and start again Photoshop.
I really need a solution for this bug/problem because it starts to driving me crazy.
I have the latest version of Photoshop 2017, up to date.
Running El Capitan on iMac 27" 5K.
Thank you.
Views
1.4K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe
Hi Remusbrm,
Please follow the steps mentioned in Troubleshoot fonts issues in Adobe Photoshop CC, 2015, 2014, CS6, CS5​ and verify that you do not have corrupt fonts or font library.
Regards,
Akash
Votes
Translate
Translate
Report
Report
Jan 31, 2017 Jan 31, 2017
Happened again this morning. And this after I checked for corrupt fonts or font library (none for both) and cleared the system font cache.
Votes
Translate
Translate
Report
Report
Please reset Photoshop preferences following http://blogs.adobe.com/crawlspace/2012/07/photoshop-basic-troubleshooting-steps-to-fix-most-issues.h... ​and let us know if that helps.
~Akash
Votes
Translate
Translate
Report
Report
Feb 06, 2017 Feb 06, 2017
Happened to me again. I think this is happening because I try to discard changes to a text box with Escape key? Don't know for sure....
I did everything you suggested.... Looks like we still don't have a solution.
Votes
Translate
Translate
Report
Report
Could you please post the report from Help>>System info here?
~Akash
Votes
Translate
Translate
Report
Report
Sure thing.
Adobe Photoshop Version: 2017.0.1 20161130.r.29 2016/11/30:23:00:00 CL 1099099  x64
Number of Launches: 68
Operating System: Mac OS 10.11.6
System architecture: Intel CPU Family:6, Model:94, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2
Physical processor count: 4
Processor speed: 3200 MHz
Built-in memory: 24576 MB
Free memory: 10751 MB
Memory available to Photoshop: 22181 MB
Memory used by Photoshop: 70 %
History Thumbnails: Enabled.
Touch Bar: Enabled.
Alias Layers: Disabled.
Modifier Palette: Disabled.
3D Multitone Printing: Disabled.
Highbeam: Enabled.
Image tile size: 128K
Image cache levels: 2
Font Preview: Medium
TextComposer: Latin
Display: 1
Main Display
High DPI Monitor
Display Bounds: top=0, left=0, bottom=1440, right=2560
Display: 2
Display Bounds: top=245, left=-1920, bottom=1325, right=0
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
NumNativeGPUs=1
glgpu[0].GLVersion="2.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=2048
glgpu[0].GLName="AMD Radeon R9 M390 OpenGL Engine"
glgpu[0].GLVendor="ATI Technologies Inc."
glgpu[0].GLVendorID=4098
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="AMD Radeon R9 M390 OpenGL Engine"
glgpu[0].GLRendererID=16915458
glgpu[0].HasGLNPOTSupport=1
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[16384]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[128]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="1.2 (Jun 30 2016 20:18:53)"
clgpu[0].CLDeviceVersion="1.2 "
clgpu[0].IsIntegratedCLGPU=0
clgpu[0].CLMemoryMB=2048
clgpu[0].CLName="AMD Radeon R9 M390 Compute Engine"
clgpu[0].CLVendor="AMD"
clgpu[0].CLVendorID=16915456
clgpu[0].CLDriverVersion="1.2 (Aug 29 2016 22:17:00)"
clgpu[0].CLBandwidth=1.27163e+11
clgpu[0].CLCompute=895.78
nativegpu[0].NativeName="AMD Metal"
License Type: Subscription
Serial number: 96040798922688529179
GUIDBucket:
  bucket: 102
  test: ReduceUXFriction
Application folder: /Applications/Adobe Photoshop CC 2017/
Photoshop scratch has async I/O enabled
Scratch volume(s):
  Startup, 951,8G, 469,5G free
Required Plug-ins folder: /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/
Primary Plug-ins folder: /Applications/Adobe Photoshop CC 2017/Plug-ins/
Installed components:
   AdbePM.framework   AdbePM   2.5.00.377243   1.578146
   adobe_caps.framework   adobe_caps   10.0.0.6   1.584361
   AdobeACE.framework   AdobeACE   2.20.02.37447   79.578171
   AdobeAGM.framework   AdobeAGM   4.30.60.37447   79.578171
   AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.8.0.34320   79.562390
   AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.8.0.34320   79.562390
   AdobeBIB.framework   AdobeBIB   1.2.03.37447   79.578171
   AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   79.578171
   AdobeCoolType.framework   AdobeCoolType   5.15.00.37447   79.578171
   AdobeCrashReporter.framework   AdobeCrashReporter   7.3.2
   AdobeExtendScript.framework   AdobeExtendScript   4.5.6.4   80.1060872
   AdobeJP2K.framework   AdobeJP2K   1.2.2.36529   79.262945
   AdobeLinguistic.framework      21429
   AdobeMPS.framework   AdobeMPS   5.8.1.37174   79.577269
   AdobeOwl.framework   AdobeOwl   5.2.11
   AdobePDFL.framework   AdobePDFL   15.0.0.36975   79.195992
   AdobePDFSettings.framework   AdobePDFSettings   1.4
   AdobePIP.framework   AdobePIP   7.4.1.60.45263
   AdobeScCore.framework   AdobeScCore   4.5.6.4   80.1060872
   AdobeSVGAGM.framework   AdobeSVGAGM   1.0.0.37447   79.578171
   AdobeSVGRE.framework   AdobeSVGRE   6.0   79.578171
   AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
   AdobeXMP.framework   AdobeXMPCore   79.159824   79.159824
   AdobeXMPFiles.framework   AdobeXMPFiles   79.159824   79.159824
   AdobeXMPScript.framework   AdobeXMPScript   79.159824   79.159824
   ahclient.framework   ahclient   2.0.0.1
   AIDE.framework   AIDE   1.5.0.36540   79.574279
   aif.framework   aif   6.0.00.1   1.
   amtlib.framework   amtlib   10.0.0.47
   boost_date_time.framework   boost_date_time   10.0.0.0
   boost_filesystem.framework   boost_filesystem   10.0.0.0
   boost_signals.framework   boost_signals   10.0.0.0
   boost_system.framework   boost_system   10.0.0.0
   boost_threads.framework   boost_threads   10.0.0.0
   Cg.framework   NVIDIA Cg
   CIT.framework
   CITThreading.framework
   dvaaudiodevice.framework   dvaaudiodevice   10.0.0.0
   dvacore.framework   dvacore   10.0.0.0
   dvamarshal.framework   dvamarshal   10.0.0.0
   dvamediatypes.framework   dvamediatypes   10.0.0.0
   dvametadata.framework   dvametadata   10.0.0.0
   dvametadataapi.framework   dvametadataapi   10.0.0.0
   dvametadataUI.framework   dvametadataUI   10.0.0.0
   dvaplayer.framework   dvaplayer   10.0.0.0
   dvatransport.framework   dvatransport   10.0.0.0
   dvaui.framework   dvaui   10.0.0.0
   dvaunittesting.framework   dvaunittesting   10.0.0.0
   dynamiclink.framework   dynamiclink   10.0.0.0
   ICUConverter.framework   ICUConverter   3.61   "gtlib_6.0" "." "21287"
   ICUData.framework   ICUData   3.61   "gtlib_6.0" "." "21287"
   ICUUnicode.framework   ICUUnicode   3.61   "gtlib_6.0" "." "21287"
   LogSession.framework   LogSession   7.4.1.60.45263
   manta.framework   manta   2.0.00.1   1.
   mediacoreif.framework   mediacoreif   10.0.0.0
   PlugPlugExternalObject.framework      7.0.0.67
   PlugPlugOwl.framework   PlugPlugOwl   7.0.0.67
   UpdaterNotifications.framework   UpdaterNotifications   10.0.0.1   "10.0.0.1"
   WRServices.framework   WRServices   12.0.0   12.0.0.1000
Required plug-ins:
   3D Studio 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
   Accented Edges 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Adaptive Wide Angle 18.0.1, Copyright © 2014-2016 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
   Angled Strokes 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Average 18.0.1  ©1993-2016 Adobe Systems Incorporated - from the file “Average.plugin”
   Bas Relief 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   BMP 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Camera Raw 9.8 (692), Copyright © 2016 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
   Camera Raw Filter 9.8 (692), Copyright © 2016 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
   Chalk & Charcoal 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Chrome 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Cineon 18.0.1  ©2002-2016 Adobe Systems Incorporated - from the file “Cineon.plugin”
   Clouds 18.0.1  ©1993-2016 Adobe Systems Incorporated - from the file “Clouds.plugin”
   Collada DAE 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
   Color Halftone 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Colored Pencil 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   CompuServe GIF 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Conté Crayon 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Craquelure 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Crop and Straighten Photos 18.0.1  Copyright © 2003-2016 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
   Crop and Straighten Photos Filter 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Crosshatch 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Crystallize 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Cutout 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Dark Strokes 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   De-Interlace 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Dicom 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “dicom.plugin”
   Difference Clouds 18.0.1  ©1993-2016 Adobe Systems Incorporated - from the file “Clouds.plugin”
   Diffuse Glow 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Displace 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Dry Brush 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Eazel Acquire 18.0.1  Copyright © 2007-2016 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
   Entropy 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
   Export Color Lookup Tables 18.0.1  Copyright ©2012-2016 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
   Extrude 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   FastCore Routines 18.0.1  ©1990-2016 Adobe Systems Incorporated - from the file “FastCore.plugin”
   Fibers 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Film Grain 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Filter Gallery 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Flash 3D 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
   Fresco 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Glass 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Glowing Edges 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Google Earth 4 KMZ 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
   Graphic Pen 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Halftone Pattern 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   HDRMergeUI 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
   HSB/HSL 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   IFF Format 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   IGES 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
   Ink Outlines 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   JPEG 2000 18.0.1  Copyright © 2001-2016 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
   Kurtosis 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
   Lens Blur 18.0.1, Copyright © 2002-2016 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
   Lens Correction 18.0.1, Copyright © 2002-2016 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
   Lens Flare 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Liquify 18.0.1, Copyright © 2001-2016 Adobe Systems Incorporated - from the file “Liquify.plugin”
   Matlab Operation 18.0.1  ©1993-2016 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
   Maximum 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
   Mean 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
   Measurement Core 18.0.1  Copyright © 1993-2016 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
   Median 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
   Mezzotint 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Minimum 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
   MMXCore Routines 18.0.1  ©1990-2016 Adobe Systems Incorporated - from the file “MMXCore.plugin”
   Mosaic Tiles 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Multiprocessor Support 18.0.1  Copyright © 1990-2016 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
   Neon Glow 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Note Paper 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   NTSC Colors 18.0.1  ©1993-2016 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
   Ocean Ripple 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   OpenEXR 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Paint Daubs 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Palette Knife 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Patchwork 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Paths to Illustrator 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   PCX 18.0.1  ©1989-2016 Adobe Systems Incorporated - from the file “PCX.plugin”
   Photocopy 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Photoshop 3D Engine 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
   Photoshop Touch Copyright ©2013-2016 Adobe Systems Incorporated - from the file “PSDX.plugin”
   Picture Package Filter 18.0.1  ©1993-2016 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
   Pinch 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Pixar 18.0.1  ©1989-2016 Adobe Systems Incorporated - from the file “Pixar.plugin”
   Plaster 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Plastic Wrap 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   PLY 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
   PNG 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Pointillize 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Polar Coordinates 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Portable Bit Map 18.0.1  ©1989-2016 Adobe Systems Incorporated - from the file “PBM.plugin”
   Poster Edges 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   PRC 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
   Radial Blur 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Radiance 18.0.1  ©2003-2016 Adobe Systems Incorporated - from the file “Radiance.plugin”
   Range 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
   Render Color Lookup Grid 18.0.1  Copyright ©2012-2016 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
   Reticulation 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Ripple 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Rough Pastels 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Save for Web 18.0.1, Copyright © 1999-2016 Adobe Systems Incorporated - from the file “Save for Web.plugin”
   ScriptingSupport 18.0.1, Copyright © 2016 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
   Shake Reduction 18.0.1, Copyright © 2014-2016 Adobe Systems Incorporated - from the file “Shake Reduction.plugin”
   Shear 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Skewness 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
   Smart Blur 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Smudge Stick 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Solarize 18.0.1  Copyright © 1993-2016 Adobe Systems Incorporated - from the file “Solarize.plugin”
   Spaces 18.0.1, Copyright © 2015 Adobe Systems Incorporated - from the file “Spaces.plugin”
   Spatter 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Spherize 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Sponge 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Sprayed Strokes 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Stained Glass 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Stamp 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Standard Deviation 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
   STL 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
   Sumi-e 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Summation 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
   Targa 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Texturizer 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Tiles 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Torn Edges 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Twirl 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   U3D 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
   Underpainting 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Vanishing Point 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
   Variance 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
   Virtual Reality Modeling Language | VRML 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
   Water Paper 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Watercolor 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Wave 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Wavefront|OBJ 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
   Wind 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Wireless Bitmap 18.0.1  ©1989-2016 Adobe Systems Incorporated - from the file “WBMP.plugin”
   ZigZag 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Optional and third party plug-ins: NONE
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
   com.adobe.inapp.purchase  2.7.122 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.DesignLibraryPanel.html/purchase.html”
   Recent Files  1.4.0 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.ccx.start/index.html”
   Sync (Beta)  1.6.8 - from the file “/Users/remusbaltariu/Library/Application Support/Adobe/CEP/extensions/com.invisionlabs.sync/index.html”
   Libraries  2.7.122 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.DesignLibraryPanel.html/index.html”
   Type  1.6.8 - from the file “/Users/remusbaltariu/Library/Application Support/Adobe/CEP/extensions/com.invisionlabs.type/index.html”
   Duplicate  1.6.8 - from the file “/Users/remusbaltariu/Library/Application Support/Adobe/CEP/extensions/com.invisionlabs.duplicate/index.html”
   Start  1.4.0 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.ccx.start/index.html”
   Export As  3.0.8 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.photoshop.crema/PSPanel/dialog.html”
   com.adobe.preview.loader  1.3.1 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.adobe.previewHD/PSLoader/loader.html”
   Photos  1.6.8 - from the file “/Users/remusbaltariu/Library/Application Support/Adobe/CEP/extensions/com.invisionlabs.photos/index.html”
   New Document  1.4.0 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.ccx.start/fnft.html”
   com.adobe.experimentation.extension  2.0.0 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.experimentation.extension/index.html”
   Zeplin  1.0.0 - from the file “/Users/remusbaltariu/Library/Application Support/Adobe/CEP/extensions/io.zeplin.photoshop-panel/index.html”
   Adobe Color Themes  6.1.0 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.KulerPanel.html/index.html”
   Device Preview  1.3.1 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.adobe.previewHD/PSPanel/panel.html”
   Subtle Patterns  1.5.3 - from the file “/Users/remusbaltariu/Library/Application Support/Adobe/CEP/extensions/com.madebysource.subtlepatterns/index.html”
Installed TWAIN devices: NONE
Votes
Translate
Translate
Report
Report
Feb 07, 2017 Feb 07, 2017
Did you reset Photoshop preferences as mentioned in the last post?
~Akash
Votes
Translate
Translate
Report
Report
Yes, I reset the Photoshop preferences this morning, and now happened again.
LE: Should I try to uninstall it and install again?
Votes
Translate
Translate
Report
Report
Feb 19, 2022 Feb 19, 2022
I have been having the same issue since yesterday. Editing layers and images is fine, but when I want to edit text in a text box, Photoshop keeps freezing and it takes AGES to make a minor change... I have reset my preferences to the original settings, have run the font test script (everything is fine), have worked on performance and scratch disks, but NOTHING HELPS. It drives me crazy, as I just cannot seem to work with text and I don't know what else I can do.
Is there someone else who can help me?
I work on a Windows 10 PC and Photoshop 2018.
Anja
Votes
Translate
Translate
Report
Report
Dec 11, 2022 Dec 11, 2022
LATEST
I'm having the same issue. I don't use Photoshop much these days (thank goodness) - but have had to the past week and this is driving me nuts. Had a lot of trouble with AE lately too. It's always 'have you tried doing this thing you'd never have thought to do?' - No. I haven't. Have YOU tried making a product that works? No need right, got our subs coming in regardless.
I'm old enough to remember the days when you paid for a license for these products and they worked flawlessly. This subscription cloud garbage has produced some of the buggiest software I have ever used.
Votes
Translate
Translate
Report
Report
