As far as I'm aware the only way to see if all images are in the proper folder is to:
Look and their paths - can take and age depending on the quantity
Copy the whole job folder to the desktop/disconnect to the server, open the INDD file and see what's missing - takes an age
Package it, then compare images - not useful if the images are in multiple folders
"copy links to" - again, not useful if the images are in multiple folders, as duplication will occur
(Mac OS Sierra / Indesign CC 2017)
It means you didn't get the entire code when you pasted or something happened when you edited.
Try this, paste it into the Script Editor application and click Compile. If that doesn't work I can post a compiled version
tell application "Adobe InDesign CC 2017"
set fname to choose folder with prompt "Select a destination folder"
set linklist to ""
tell active document
repeat with theLink in every link
set theLinkPath to file path of theLink
...Copy link to clipboard
Hmmm...you really haven't stated a clear objective other than:
...to see if all images are in the proper folder...
But then it seems as though you contradict the notion of "proper folder," by disqualifying packaging, which essentially guarantees (copies of) all linked images are in "the proper folder".
It's not that I'd argue with you with regard to duplication (acknowledged by the reference to 'copies of' above), but realistically, you can't have it both ways; a single, "proper folder" containing all a document's linked images, and zero duplication. If, over the editing history of a document, images were placed from multiple folders outside of the one you'd consider "the proper folder", it's reasonable to assume the images reside in those other locations for a reason; perhaps they are placed in other documents as well.
Where most of my work is carried out, we embrace that duplication and package everything for archiving and life-cycle control; ensuring that no document is dependent on a linked graphic that could become unavailable. Storage is cheap.
The 'proper folder' in question is the current project inks folder. I want to see if there are links from previous jobs in the current project/job.
These are live jobs and I want to keep tabs on what's linked. If a previous job is archived/moved/renamed while this one is live, and there's a link to that job, then the link will go missing.
When the job is signed off then packaging is done and ready to archive.
It would be scriptable. You could try this AppleScript, which asks you to choose a folder then makes a list of all links not in that folder:
tell application "Adobe InDesign CC 2014"
set linklist to ""
set theLinkPath to file path of theLink as alias
tell application "Finder"
set a to name of parent of theLinkPath
set b to name of fname
end tell
if a is not equal to b then
set n to name of theLink
set linklist to linklist & n & return
end if
end repeat
end tell
display dialog "These placed files are not in the selected folder:" & return & linklist
end tell
Cheers Rob, I'll give it a spin tomorrow.
Hi rob, sorry about the long delay in responding. Gave it a whirl but this happened:
not knowing anything about scripting I really don't know what this means
BTW I'm using Adobe InDesign CC 2017, I changed that in the script you posted.
set linklist to ""
end tell
end if
end repeat
end tell
end tell
That worked!
But,
I found that if the file has a QR coded generated within the file you get:
and if there's am embedded image this happens:
But having said that it's very rare that we use QR Codes - or - embed images! It was just coincidence that the first 2 files had them
Thanks rob, I'll send this round the studio for a test!
Try this:
set linklist to ""
try
end tell
on error
set a to ""
end try
end if
end repeat
end tell
if linklist is not "" then
else
display dialog "All links are in the selected folder"
end if
end tell
Select all your links in the links panel and copy to folder.
http://indesignsecrets.com/copy-all-your-linked-images.php
It won't copy anything into the folder twice - it just copies what's not there + it relinks them to that folder.
Indesign doesn't look inside sub folders, just chucks them in one big bucket
