1 2 Previous Next 41 Replies Latest reply on Mar 14, 2017 5:00 PM by jbm007
    All photoshop versions are crashing
    Micksolee Level 1
      Before I start, thank you in advance. Copied from another forum post. I hope anyone here will be able to help.
      I got a big problem. Photoshop keeps crashing and I tried alot of things that were suggested on the web. Resetting preferences, reinstalling, removing plugins/fonts, enable/disable Graphics/ Processor/open GL and disable auto save feature. I used photoshop cc, cs6 32/64bit version. Does anyone have any idea what could be the case?
      Edit: this happened recently, I have been using ps for atleast 8 years
      Edit: It doesnt crash if I just open it, mostly during the drawing (using the tablet) after 5-60 minutes. If i go away for some hours it doesn't crash at all.
      Edit: I use win10 and updating my tablet drivers did indeed stop the crashing for a day.
      Edit: I did several test for my ram. No problems were shown.
      Edit: Tried replugging the tablet before and during photoshop. Nothing happened.
      Looked into my event folder: I have no idea what it means..
      Faulting application name: Photoshop.exe, version: 13.0.0.0, time stamp: 0x4f61c045
      Faulting module name: Photoshop.exe, version: 13.0.0.0, time stamp: 0x4f61c045
      Exception code: 0xc0000005
      Fault offset: 0x0000000001721135
      Faulting process ID: 0x3bb8
      Faulting application start time: 0x01d27b48d06953dd
      Faulting application path: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Photoshop.exe
      Faulting module path: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Photoshop.exe
      Report ID: f39cfed5-196c-4000-948e-8306110769f6
      Faulting package full name:
      Faulting package-relative application ID:
        • 1. Re: All photoshop versions are crashing
          Mohit Goyal Adobe Employee (Admin)
          Hi Micksolee,
          Please create another user account on your windows machine and check the Photoshop version there, also update the graphics drivers from the manufacture website.
          Let us know if that helps.
          Regards,
          Mohit
          • 2. Re: All photoshop versions are crashing
            gener7 Adobe Community Professional & MVP
            You should also update Photoshop. You have 13.0.0.0
            Adobe - Photoshop : For Windows : Adobe Photoshop 13.0.1.3 update for CS6
            • 3. Re: All photoshop versions are crashing
              Micksolee Level 1
              I tried using file to update cs6, it didn't update.
              Even If this would work, photoshop cc doesn't work and crashes aswell. Like, does it matter that I have 2015? I see no point on paying if this problem percists.
              Any help is appreciated, though this is getting frustated.
              I got mail saying that I could contact someone with skype. Is this a legit person (Clive Davey.Adobe) or someone trying to hack?
              • 4. Re: All photoshop versions are crashing
                I'll do some digging around...
                No one is supposed to be contacting you via Skype. All questions are answered in this forum. Ignore it.
                If you have CC 2015, you can open a chat with Adobe Customer Care. They are Adobe Support, we are User to User Support.
                Contact Customer Care   They have the resources to look at your Mac and can really help.
                Gene
                • 5. Re: All photoshop versions are crashing
                  You mentioned you have CC 2015.  CC 2017.0.1 is now the latest and part of your subscription.
                  Install it (you may keep CC 2015) and see if it works.
                  Plugins and System fonts can cause problems. Look at this guide and see if you can eliminate that cause.
                  http://blogs.adobe.com/crawlspace/2012/07/photoshop-basic-troubleshooting-steps-to-fix-mos t-issues.html
                  • 6. Re: All photoshop versions are crashing
                    jbm007 Adobe Community Professional
                    Try running SFC/ SCANNOW  from the command prompt run  command prompt with "administrative right" see if it brings up any issues.
                    • 7. Re: All photoshop versions are crashing
                      Micksolee Level 1
                      No problems were found with any possible corrupted files.
                      • 8. Re: All photoshop versions are crashing
                        Micksolee Level 1
                        Used the latest version of 2017, to see if I would DC.
                        This came out of the windows event viewer. Disableing plugins/fonts, yes done it aswell.
                        It was over roughly 2 hours of drawing using a tablet I dc'ed. Perhaps any problems, caused by the tablet that would make photoshop crash? It's up to date ofcourse. I use a intuos 4 PTK 840. I don't crash when photoshop is openend (for Hours).
                        Faulting application name: Adobe Spaces Helper.exe, version: 0.0.0.0, time stamp: 0x583e8a7d
                        Faulting module name: libcef.dll, version: 3.2526.1347.0, time stamp: 0x572d0cf0
                        Fault offset: 0x0000000002656a65
                        Faulting process ID: 0xf4
                        Faulting application start time: 0x01d27c7018af6a2a
                        Faulting application path: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-Ins\Spaces\Adobe Spaces Helper.exe
                        Faulting module path: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-Ins\Spaces\libcef.dll
                        Report ID: 89a21009-dd92-4b70-9706-6a84a78c2e86
                        • 9. Re: All photoshop versions are crashing
                          Do you have Trend Micro products installed?
                          • 10. Re: All photoshop versions are crashing
                            See if going to Edit>Preferences>General, unchecking Show Messages and restarting photoshop makes any difference.
                            R_Kelly
                            • 11. Re: All photoshop versions are crashing
                              Micksolee Level 1
                              If am correct this is a specific internet security program or all inti virus programs in general? If its the second option, then I only have malwarebythe and Mcafee securtity Scan Plus as anti virus programs.
                              • 12. Re: All photoshop versions are crashing
                                Spaces crashing is a separate issue from Security or AV programs. Either the above fix helps or simply placing a tilde before the Spaces folder.
                                libcef.dll as a faulting module points to windows not being updated.
                                • 13. Re: All photoshop versions are crashing
                                  Micksolee Level 1
                                  I did read some solution about putting a tilde infront of certain files or maps. However, I'm not completely sure what to do. I put a ~ infront of the security programs folder?
                                  • 14. Re: All photoshop versions are crashing
                                    Here we go: Photoshop CC 2017: Adobe Spaces Helper crash | Photoshop Family Customer Community
                                    Same crash report as you gave.
                                    Put the tilde here: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-Ins\~Spaces
                                    • 15. Re: All photoshop versions are crashing
                                      Micksolee Level 1
                                      I put a tilde infront of the spaces map.
                                      Tried using a different tablet.
                                      No trend micro programs installed, atleast of the ones am aware of.
                                      If I would ask someone from the adobe support to help me with these problems are there costs attached to it. Or do I have the rights as paying customer for technician.
                                      Here are some more crash logs:
                                      Faulting application name: Photoshop.exe, version: 18.0.1.29, time stamp: 0x583e911d
                                      Faulting module name: Photoshop.exe, version: 18.0.1.29, time stamp: 0x583e911d
                                      Fault offset: 0x0000000007f6dc35
                                      Faulting process ID: 0x1c48
                                      Faulting application start time: 0x01d27ce1f6167f9e
                                      Faulting application path: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Photoshop.exe
                                      Faulting module path: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Photoshop.exe
                                      Report ID: 11622e9e-4022-4153-8f38-1bcbb6cf6f83
                                      Faulting process ID: 0x14a8
                                      Faulting application start time: 0x01d27cdc8d6821c7
                                      Report ID: 6ae43df1-4ebf-44d8-b5ad-8fbd11d275a5
                                      Faulting process ID: 0x2ea4
                                      Faulting application start time: 0x01d27cdff3c6e036
                                      Report ID: deb881fb-9b4d-40bc-9e0f-76032e1f773e
                                      Faulting process ID: 0x1a60
                                      Faulting application start time: 0x01d27cd8348be15f
                                      Report ID: 8527c0be-a510-4862-ab95-8a5094d85311
                                      • 16. Re: All photoshop versions are crashing
                                        Customer Care Chat is absolutely free and a part of your subscription. I'm out of ideas and they can best help you.
                                        Give them as much detail as you can.
                                        Gene
                                        • 17. Re: All photoshop versions are crashing
                                          You might want to run a program called CCleaner to clean up your registry file.
                                          CCleaner - The world's most popular PC cleaner & optimization tool - Piriform
                                          Something is buggered up on your machine, and your windows registry is not sorting things out properly.
                                          • 18. Re: All photoshop versions are crashing
                                            Micksolee Level 1
                                            I used CCleaner and after 3 hours of drawing I crashed. Am going to give the support a shot.
                                            Latest crash report:
                                            Faulting process ID: 0x2a58
                                            Faulting application start time: 0x01d27d318bf944df
                                            Report ID: b3bbbef2-ecde-442f-8fa6-627ab79fba9c
                                            • 19. Re: All photoshop versions are crashing
                                              Gerwinmorren Level 1
                                              Try to reinstall your photoshop? Probably you did that alleady but just saying.
                                              • 20. Re: All photoshop versions are crashing
                                                Could you make sure your Microsoft Framework that is installed is up to date?
                                                • 21. Re: All photoshop versions are crashing
                                                  Micksolee Level 1
                                                  Both support and this forum failed to give a good solution.
                                                  I haven't crashed for 3 days.
                                                  fix for this crashing: remove active brushes.
                                                  • 22. Re: All photoshop versions are crashing
                                                    Thanks for reporting back. I never heard of brushes causing Photoshop to crash. Very unusual.
                                                    When you said "removed active brushes", how exactly did you do that? What brushes were they?
                                                    • 23. Re: All photoshop versions are crashing
                                                      Micksolee Level 1
                                                      I'll leave this here. I hope for future cases, people might try this out. I still haven't crashed.
                                                      And I just removed all brushes, not the tools though. I haven't figured out what brush exactly makes me crash.
                                                      Random Photoshop Crashes
                                                      • 24. Re: All photoshop versions are crashing
                                                        Micksolee Level 1
                                                        Well it crashed again. I'll switch to laptop, anyway. Thx for the help.
                                                        • 25. Re: All photoshop versions are crashing
                                                          Can you post the new crash report when you get a chance?
                                                          • 26. Re: All photoshop versions are crashing
                                                            Micksolee Level 1
                                                            Here you go, I also got errors outside photoshop. perhaps it could help.
                                                            Faulting process ID: 0x3438
                                                            Faulting application start time: 0x01d27f8ef2053f4c
                                                            Report ID: 9694bb4f-7967-460a-9d15-1fc8e7975af4
                                                            Fault bucket 63490781, type 4
                                                            Event Name: APPCRASH
                                                            Response: Not available
                                                            Cab Id: 0
                                                            Problem signature:
                                                            P1: Photoshop.exe
                                                            P2: 13.0.0.0
                                                            P3: 4f61c045
                                                            P4: Photoshop.exe
                                                            P5: 13.0.0.0
                                                            P6: 4f61c045
                                                            P7: c0000005
                                                            P8: 0000000001721135
                                                            P9:
                                                            P10:
                                                            \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3783.tmp.WERInternalMetadata.xml
                                                            These files may be available here:
                                                            C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_Photoshop.exe_9dd54ecb5ffa93e5 79bde21b35f2ede6994c5_384fdc3d_19fc5859
                                                            Analysis symbol:
                                                            Rechecking for solution: 0
                                                            Report Status: 0
                                                            Hashed bucket: f5e82e5b2a3a7fcb023a7b5777de7f10
                                                            Windows errors I think:
                                                            The Open Procedure for service "BITS" in DLL "C:\Windows\System32\bitsperf.dll" failed. Performance data for this service will not be available. The first four bytes (DWORD) of the Data section contains the error code.
                                                            The Open Procedure for service "ESENT" in DLL "C:\WINDOWS\system32\esentprf.dll" failed. Performance data for this service will not be available. The first four bytes (DWORD) of the Data section contains the error code.
                                                            The Open Procedure for service "Lsa" in DLL "C:\Windows\System32\Secur32.dll" failed. Performance data for this service will not be available. The first four bytes (DWORD) of the Data section contains the error code.
                                                            The Open Procedure for service "MSDTC" in DLL "C:\WINDOWS\system32\msdtcuiu.DLL" failed. Performance data for this service will not be available. The first four bytes (DWORD) of the Data section contains the error code.
                                                            Unable to open the Server service performance object. The first four bytes (DWORD) of the Data section contains the status code.
                                                            The Open Procedure for service "WmiApRpl" in DLL "C:\WINDOWS\system32\wbem\wmiaprpl.dll" failed. Performance data for this service will not be available. The first four bytes (DWORD) of the Data section contains the error code.
                                                            • 27. Re: All photoshop versions are crashing
                                                              Could you make sure you have the latest version of Microsoft framework
                                                              installed?
                                                              https://www.microsoft.com/en-us/download/details.aspx?id=30653
                                                              • 28. Re: All photoshop versions are crashing
        You'll need to update that. 13.0.0.0 is the base version, 13.0.1.3 is the latest.
        Not sure if that will stop the crashing, but at least get that out of the equation.
        • 29. Re: All photoshop versions are crashing
        Micksolee Level 1
        Both framework and updated to trough CC.
        And please, don't tell me I need to update to 13.1.3. since it creative cloud won't update further.
        I can't find any more solutions.
        This is the crash report:
        Faulting application name: Photoshop.exe, version: 13.1.2.0, time stamp: 0x50e86765
        Faulting module name: Photoshop.exe, version: 13.1.2.0, time stamp: 0x50e86765
        Fault offset: 0x000000000173cff5
        Faulting process ID: 0x333c
        Faulting application start time: 0x01d27fd0cf0d7a47
        Report ID: 27a36149-406f-4499-b703-9a497597a9be
        Information:
        Fault bucket 92423129, type 4
        Cab Id: 0
        Problem signature:
        P1: Photoshop.exe
        P2: 13.1.2.0
        P3: 50e86765
        P4: Photoshop.exe
        P5: 13.1.2.0
        P6: 50e86765
        P7: c0000005
        P8: 000000000173cff5
        P9:
        P10:
        \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER75DB.tmp.WERInternalMetadata.xml
        C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_Photoshop.exe_20a851ffa011e268 6bc8144db1cf4c19926f5874_185f72d9_1525c255
        Analysis symbol:
        Report Status: 0
        Hashed bucket: df76174906be4966629374643fd910a6
        • 30. Re: All photoshop versions are crashing
        thealphasspark
        I'm having the same problem, I've reset Win10, I've reinstalled PS cc 2017 twice in the last week, checked the framework is updated, have tried a direct install and a cc install. My firewalls are set to allow. I've been trying EVERY suggestion that's been made.
        It's just getting worse, I only have to open it and it crashes within 30 seconds and freezes my whole laptop. Meaning having to do a hard shutdown of my laptop, then switch it back on and doing a restart straight away to get everything working again. Not to forget with every reinstall having to reinstall my, Nik, Topaz and ImageNomic filters. On the matter of filters, the lookup adjustments filters aren't working properly either. The whole point of paying for Photoshop was to not have to go through this crap.
        Get on and fix this Adobe, you're quick enough to take our cash.
        • 31. Re: All photoshop versions are crashing
        Can you post the crash report here.
        go to
        control panel/administrative tools/event viewer/windows logs/application find the PS crash, select it and go to right "copy as text" and post it here.
        • 32. Re: All photoshop versions are crashing
        thealphasspark Level 1
        OK, I'm hoping these are the right ones. There's a bunch of these. I uninstalled PS and reinstalled it again today as I couldn't open it at all. Post reinstall stayed open for about 5 mins then crashed again. Thanks for looking at this.
        Log Name:  Application
        Source:    Application Error
        Date:      12/02/2017 18:13:27
        Event ID:  1000
        Task Category: (100)
        Level:     Error
        Keywords:  Classic
        User:      N/A
        Computer:  Acer
        Description:
        Fault offset: 0x00000000026569af
        Faulting process ID: 0x1fac
        Faulting application start time: 0x01d2855b90a63ab6
        Report ID: f06d5c74-a8dd-423f-aded-ba1095b255ea
        Event Xml:
        <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
        <System>
        <Provider Name="Application Error" />
        <EventID Qualifiers="0">1000</EventID>
        <Level>2</Level>
        <Task>100</Task>
        <Keywords>0x80000000000000</Keywords>
        <TimeCreated SystemTime="2017-02-12T18:13:27.225928900Z" />
        <EventRecordID>2050</EventRecordID>
        <Channel>Application</Channel>
        <Computer>Acer</Computer>
        <Security />
        </System>
        <EventData>
        <Data>Adobe Spaces Helper.exe</Data>
        <Data>0.0.0.0</Data>
        <Data>583e8a7d</Data>
        <Data>libcef.dll</Data>
        <Data>3.2526.1347.0</Data>
        <Data>572d0cf0</Data>
        <Data>c0000005</Data>
        <Data>00000000026569af</Data>
        <Data>1fac</Data>
        <Data>01d2855b90a63ab6</Data>
        <Data>C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-Ins\Spaces\Adobe Spaces Helper.exe</Data>
        <Data>C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-Ins\Spaces\libcef.dll</Data>
        <Data>f06d5c74-a8dd-423f-aded-ba1095b255ea</Data>
        <Data>
        </Data>
        <Data>
        </Data>
        </EventData>
        </Event>
        Event ID:  1000
        Level:     Error
        Keywords:  Classic
        User:      N/A
        Computer:  Acer
        Description:
        Faulting process ID: 0x161c
        Faulting application start time: 0x01d2855b90a4374c
        Report ID: 0a5627b5-3f1c-4683-a2c2-083201b366a8
        Event Xml:
        <System>
        <Level>2</Level>
        <Task>100</Task>
        <EventRecordID>2051</EventRecordID>
        <Security />
        </System>
        <EventData>
        <Data>161c</Data>
        <Data>01d2855b90a4374c</Data>
        <Data>0a5627b5-3f1c-4683-a2c2-083201b366a8</Data>
        <Data>
        </Data>
        <Data>
        </Data>
        </EventData>
        </Event>
        Date:      12/02/2017 18:13:17
        Event ID:  1000
        Level:     Error
        Keywords:  Classic
        User:      N/A
        Computer:  Acer
        Description:
        Faulting module name: nvoglv64.DLL, version: 21.21.13.7849, time stamp: 0x58820dae
        Exception code: 0xc0000409
        Fault offset: 0x0000000000f8d778
        Faulting process ID: 0x24ec
        Faulting application start time: 0x01d2855b8e909d8f
        Faulting module path: C:\WINDOWS\SYSTEM32\nvoglv64.DLL
        Report ID: b63e1aa2-321c-4494-96eb-d2d7f6c3eeae
        Event Xml:
        <System>
        <Level>2</Level>
        <Task>100</Task>
        <TimeCreated SystemTime="2017-02-12T18:13:17.639355900Z" />
        <EventRecordID>2047</EventRecordID>
        <Security />
        </System>
        <EventData>
        <Data>Photoshop.exe</Data>
        <Data>18.0.1.29</Data>
        <Data>583e911d</Data>
        <Data>nvoglv64.DLL</Data>
        <Data>21.21.13.7849</Data>
        <Data>58820dae</Data>
        <Data>c0000409</Data>
        <Data>0000000000f8d778</Data>
        <Data>24ec</Data>
        <Data>01d2855b8e909d8f</Data>
        <Data>C:\Program Files\Adobe\Adobe Photoshop CC 2017\Photoshop.exe</Data>
        <Data>C:\WINDOWS\SYSTEM32\nvoglv64.DLL</Data>
        <Data>b63e1aa2-321c-4494-96eb-d2d7f6c3eeae</Data>
        <Data>
        </Data>
        <Data>
        </Data>
        </EventData>
        </Event>
        • 33. Re: All photoshop versions are crashing
        You have two issues.
        First one is your video driver.
        You need to go to the laptop site and download the latest video driver for your system.
        Second after you install the video driver and reboot you are having a windows .dll conflict somewhere.
        Find this path:C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-Ins\Spaces\libcef.dll
        rename \libcef.dll   to something like oldlibcef.dll
        and try running PS again.
        2 people found this helpful
        • 34. Re: All photoshop versions are crashing
        Hi
        Tried updating manually but kept being told drivers are up to date. I've used a driver updater software and amended the .dll. Rebooted and still not working. If anything it's getting worse, can't even load an image before it crashes. Will probably go through support tomorrow as I've tried everything else.
        Thanks for the help though.
        • 35. Re: All photoshop versions are crashing
        Did you go to the laptop site and download the latest version on their site?
        Don't use the windows updater program.
        I have reviewed the crash report you posted.
        It is definitely related to the Nvidia driver.
        is a Nvidia driver component.
        This laptop doesn't have a dual GPU chipset does it?
        • 36. Re: All photoshop versions are crashing
        Once you know the kind of graphics card you have, visit the manufacturer's website to download the latest driver. Here are links for downloading drivers from the most common graphics card manufacturers:
        * NVIDIA: http://www.nvidia.com/content/drivers/drivers.asp
        • 37. Re: All photoshop versions are crashing
        OK so uninstalled NVIDIA completely and reinstalled directly from NVIDIA. Seems to be working ok. I'm off to bed now so, will check it out tomorrow properly. Dual Chip set? Sorry if you mean if it has two graphics drivers? then yes and, I'm guessing the're not integrated as NVDIA has it's own control panel? I'm not 100% on this stuff to be honest. Just try to muddle through. Thanks for all the help : )
        • 38. Re: All photoshop versions are crashing
        Thanks had worked my way there but definetly seems to have worked, handy for other users though.Thanks  : )
        • 39. Re: All photoshop versions are crashing
        With the Nvidia Control Panel, you would set your Nvidia card as the dedicated card for Photoshop and the GPU sniffer. Having automatic card switching does bring on issues.
        1 2 Previous Next
