5 Replies Latest reply on Jan 31, 2017 11:15 AM by TᴀW
    Simple PDF exporting script from InDesign
    dicom75886549 Level 1
      I'm trying for the beginning of my planned script to just export a simple PDF to a destination with the Scripting UI. Here is my code:
      var genFenster = new Window ("dialog", "PG beta");
      // Knopf für das generieren vom PDF Dokument
      var genKnopf = genFenster.add ("button", undefined, "Generieren");
      genKnopf.onClick = function () {
          app.activeDocument.exportFile(ExportFormat.pdfType, File("testDocument.pdf"), false);
      genFenster.show ();
      Tried to debug it inside ExtendScript but it just enters a loop where it cannot force InDesign to finish it. I've marked with the red color where ExtendScript gets stuck.
      Please help me get this started.
        • 1. Re: Simple PDF exporting script from InDesign
          TᴀW Adobe Community Professional & MVP
          Try something like this:
              genFenster.close(100);
          var result = genFenster.show();
          if (result === 100){
          The problem with your script is that a modal dialog is open, and when it's open, InDesign can't do anything.
          The solution is to close the dialog, and then perform the required InDesign function.
          the close() function of a window can take any number, and it is passed to the show() method, so that way you can check what button was pressed, close the window, and act accordingly.
          Ariel
          • 2. Re: Simple PDF exporting script from InDesign
            Thanks man, it works. I can develop it further now. Weird approach. It's important that I understand your code since I need to develop it to reopen the dialog after the export completes.
            • 3. Re: Simple PDF exporting script from InDesign
              If you need to reopen the dialog, you may be better off doing things differently.
              Instead of using a "dialog"-type window, use a "palette" type window.
              Palette-type windows are modeless (like InDesign's Find/Change dialog), which lets the user do things in InDesign even while the dialog is open.
              However, it gets a little fiddly with a palette, because as soon as it is opened, the script terminates, and then it is destroyed, so it disappears.
              The solution to that is to create a custom script engine, which is much easier than it sounds. So, modifying the example as follows should do the trick:
              #targetengine MyNewEngine
              var genFenster = new Window ("palette", "PG beta");
              genFenster.show();
              (By the way, your original suggestion of reopening the window after closing it doesn't work. I seem to recall that once a window is closed, it can't just be reopened with myWindow.show() again...)
              Edit: Sorry, I've corrected the script here now (the first version in this post was not demonstrating the use of a palette properly).
              • 4. Re: Simple PDF exporting script from InDesign
                I've tried it with doScript but your solution is far better. This settles my first step towards my automation script. Thanks so much. Looks like I need to read more into the documentation. I was aware of pallete type just was to scared to implement it, because I was not sure if it would make problems in the future. Seems like it's totally fine.
                • 5. Re: Simple PDF exporting script from InDesign
                  Peter Kahrel makes it all seem so easy:
                  http://www.kahrel.plus.com/indesign/scriptui.html
                  Highly recommended!
                  Ariel
