Community,
So essentially, I want to number these illustration descriptions. I began by creating a paragraph style but found that because the frames aren't linked, the numbering doesn't increment (I'm sure this is fixable right?). So as a work-around, I've begun linking the frames but then found that the the text doesn't wrap within a frame meaning that it spills over to the next despite there being sufficient space within the fame to fit the text.
Apologies, I know the solutions are relatively simple but can't see the wood for the trees right now.
Many Thanks
Without linking them together, I think you can use the method described in this numbering captions tutorial by Bob Bringhurst:
