1 Reply Latest reply on Feb 1, 2017 10:17 AM by vangroover
    Android build failing on multiple random errors
    jenkinsc61559208
      Hi Guys,
      in last few days I have been experiencing that my Android build is randomly failing.
      I have tried to build older code, which was working without any issues and even that
      is failing with multiple random errors. My iPhone build is working without any issues.
      App ID: 2139910
      Here are 2 errors, which I have experienced today:
      :preDexReleaseOpenJDK 64-Bit Server VM warning: INFO: os::commit_memory(0x00000000ef000000, 62914560, 0) failed; error='Cannot allocate memory' (errno=12)
      FAILED
      FAILURE: Build failed with an exception.
      * What went wrong:
      Execution failed for task ':preDexRelease'.
      > com.android.ide.common.internal.LoggedErrorException: Failed to run command:
        /android-sdk/build-tools/24.0.1/dx --dex --output /project/build/intermediates/pre-dexed/release/classes-fe24083014f5bc8e84aa6f5b627e64e0d6 99cf66.jar /project/build/intermediates/exploded-aar/com.android.support/support-compat/25.1.0/class es.jar
        Error Code:
        1
        Output:
      :preDexRelease
      :dexRelease
      UNEXPECTED TOP-LEVEL EXCEPTION:
      com.android.dex.DexException: Multiple dex files define Landroid/support/v4/accessibilityservice/AccessibilityServiceInfoCompat$AccessibilityServ iceInfoVersionImpl;
        at com.android.dx.merge.DexMerger.readSortableTypes(DexMerger.java:591)
        at com.android.dx.merge.DexMerger.getSortedTypes(DexMerger.java:546)
        at com.android.dx.merge.DexMerger.mergeClassDefs(DexMerger.java:528)
        at com.android.dx.merge.DexMerger.mergeDexes(DexMerger.java:164)
        at com.android.dx.merge.DexMerger.merge(DexMerger.java:188)
        at com.android.dx.command.dexer.Main.mergeLibraryDexBuffers(Main.java:504)
        at com.android.dx.command.dexer.Main.runMonoDex(Main.java:334)
        at com.android.dx.command.dexer.Main.run(Main.java:277)
        at com.android.dx.command.dexer.Main.main(Main.java:245)
        at com.android.dx.command.Main.main(Main.java:106)
      FAILED
      * What went wrong:
      Execution failed for task ':dexRelease'.
        /android-sdk/build-tools/24.0.1/dx --dex --output /project/build/intermediates/dex/release --input-list=/project/build/intermediates/tmp/dex/release/inputList.txt
        Error Code:
        2
        Output:
      Thanks in advance for your help.
