2 Replies Latest reply on Feb 1, 2017 11:01 AM by RayKIII
    Auto Fill two fields depending on text in another field
    RayKIII
      Working with Adobe Acrobat Pro DC
      I am trying to fill two other text fields with different information depending on what is entered into a third text field.  Here is the script I put together, but it is not working.  I have tried to set it to Select Trigger: Mouse Up and Mouse Enter also.  Any suggestions?
      var v = event.target.value;
      var f4 = this.getField("Days available");
      var f5 = this.getField("Pay Level");
      if (v != "1") {
          f4.value = "3";
        f5.value = "1";
      else if (v != "2") {
          f4.value = "4";
        f5.value = "1";
      else if (v != "3") {
          f4.value = "5";
        f5.value = "2";
      else if (v != "4") {
          f4.value = "6";
        f5.value = "3";
        • 1. Re: Auto Fill two fields depending on text in another field
          What exactly is happening when you enter a value?
          Did you check the Acrobat JavaScript console for any errors?
          What do you want to happen if none of the expected values is entered?
          I would consider using the equality operator and not the no equal operator.
          • 2. Re: Auto Fill two fields depending on text in another field
            RayKIII Level 1
            Sorry, I am very new to writing scripts.  As soon as I select the text field it puts 3 and 1 in the other fields.  If I enter another number then nothing happens.
            Where do I find the JavaScript console?
            Sorry I had added the following at the end for when there was something else put in the field and forgot to put that in original post.
            else {
                f4.value = "0";
              f5.value = "0";
            Thank you for pointing out the no equal operator.  That appears to have been my problem, thank you very much for your help for such a silly problem.
