28 Replies Latest reply on Feb 13, 2017 1:37 PM by Eileen987
    Subtraction from multiple fields result is incorrect.
    Eileen987 Level 1
      I have been attempting to calculate a subtraction javascript in acrobat X. (i am an inexperienced javascript coder and found part of this this in a search online.  I made some assumptions and elaborated the rest)
      This is my javascript:
      // Get first field value
      var v1 = getField("Qty Recd").value;
      // Get second field value
      var v2 = getField("Text4.0.1").value;
      // Get third field value
      var v3 = getField("Text4.1.1").value;
      // Get fourth field value
      var v4 = getField("Text4.2.1").value;
      // Get fifth field value
      var v5 = getField("Text4.3.1").value;
      // Get sixth field value
      var v6 = getField("Text4.4.1").value;
      // Get seventh field value
      var v7 = getField("Text4.5.1").value;
      // Get eighth field value
      var v8 = getField("Text4.6.1").value;
      // Get ninth field value
      var v9 = getField("Text4.7.1").value;
      // Get tenth field value
      var v10 = getField("Text4.8.1").value;
      // Get eleventh field value
      var v11 = getField("Text4.9.1").value;
      // Set this field value equal to the difference
      event.value = v1-v2;-v3;-v4;-v5;-v6;-v7;-v8;-v9;-v10;-v11;-v12;-v13;-v14
      When I test the calculation, initially the result is correct.  However, when I change one of the values to another number or delete it, the result continues to subtract what was initially entered in the field.  How do I correct this?  .
      I have been trying different things and searching for help for two days.
      Can anyone figure out what I am doing wrong?  And then help me correct it?
      Thank you Emelone
