11 Replies Latest reply on Oct 6, 2018 11:37 AM by Silly-V
    Apply Live Effect: Inner Glow with color
    Silly-V Adobe Community Professional
      With help of some great information, Prometheus-like, we have been given the access to the syntax which makes pageItem.applyEffect(); work
      Re: PageItem.applyEffect(LiveEffectXML)
      This is great to start out with when the components which make up the 'Dict data="' string are in a straight-forward syntax where there is a data type, a name key and a value to form each component. They just need to be strung together like so:
      1. xmlstring = '<LiveEffect name="Adobe Offset Path"><Dict data="R mlim 4 R ofst 20 I jntp 2 "/></LiveEffect>'
      I am able to almost accomplish my goal of applying an Inner Glow, but I can't figure out the syntax needed to supply the glow color to go along with it. It always defaults to white.
      Here is the code so far which applies a glow only with white default:
      #target illustrator
      function test(){
        var effectStr =
         '<LiveEffect name="Adobe Inner Glow">' +
             '<Dict data="' +
                 'I gtyp 0 ' +
                 'R blur 14.4 ' +
                 'I blnd 3 ' +
                 'R opac 1 ' +
         '</LiveEffect>';
        var doc = app.activeDocument;
        var s = doc.selection[0];
        s.applyEffect(effectStr);
      test();
      Here is the string inside the .AI file I saved without compression and opened it as text:
      /BasicFilter :
      (Adobe Inner Glow) 1 0 /Filter ,
      1 /Visible ,
      (Adobe Illustrator.app) /PluginFileName ,
      (Inner Glow) /Title ,
      /Dictionary : /NotRecorded ,
      0 /Int (gtyp) ,
      /FillStyle : 0 O
      0.03 0 0.29 0 k
      0 1 0 0 0 Xy
      0 J 0 j 1 w 10 M []0 d
      0 XR
      0 1 Xd
      /Def ;
      (gclr) ,
      14.4 /Real (blur) ,
      1 /Real (opac) ,
      3 /Int (blnd) ,
      ; /Dict ;
      The color information is located here:
      /FillStyle : 0 O
      0.03 0 0.29 0 k
      0 1 0 0 0 Xy
      0 XR
      0 1 Xd
      /Def ;
      (gclr) ,
      While the rest of the 4 properties are working in my attempt above, I can't get the right syntax for putting in that color.
      By the way, when applying this effect with experimentation strings added, the result could be an error-less application of the effect with default white or a MRAP, depending on whether you crossed some line of what the acceptable syntax is. I have tried adding new attributes and tags, and it still worked in the default way. Then I tried to add a nested tag inside the Dict tag, and got a MRAP. Whoever is able to solve this puzzle shall be rewarded with several emojis.
