• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
C4D File in After Effects - Frame limit?
Community Beginner ,
Feb 02, 2017 Feb 02, 2017
Hi;
I have an after effects file where i have a C4D file placed in it. i'm rendering out the C4D file with cel renderer, so its a 3d object, with a 2d look, then in after effects having type that comes in and out in relation to the c4d objects movement.
I have communication turned on between the two apps so that my timeline is linked, and they are both set to 25fps.
However since adding to the movements and extending the amount of frames in the C4D file, these changes aren't reflected in AE. i've reloaded the footage or 'file', re-imported it onto the timeline everything. Normally if its another comp that you make longer, you just drag out the block on the timeline but whatever i do this c4d file stops in AE at 208 frames, even though the animation is 350frames.
I'm stuck! any ideas?
Views
829
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
This is normal. Once the C4D file has been imported it is just a layer like any other and AE never auto-extends a comp. You have to set these options in the composition settings manually.
Mylenium
Votes
Translate
Translate
Report
Report
Hello, i'm not sure what you mean tho, the comp settings are set to 350frames, as is the c4d, but in AE the c4d file stops at 208f....
Votes
Translate
Translate
Report
Report
LEGEND ,
Well, have you actually set the active range in the C4D timeline accordingly? Just changing the scene settings may not be enough.
Mylenium
Votes
Translate
Translate
Report
Report
Is that Project settings > min / max time?projectsettings.png
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Mar 02, 2017 Mar 02, 2017
LATEST
Hi there ScottM,
Oh my gosh, sorry we dropped the ball there. Assume that was a "yes?" Did you get your project completed? Any tips other people could use? Please let us know how it all turned out for you or if you still need help.
Kevin
Votes
Translate
Translate
Report
Report
