Having dell xps 8300
How good is the performance of i7 2600 in after effects and premiere pro? I am going to use it as a starter. Will upgrade within a year or 6 months... Just wanted to know will it fair for a beginner?
Motherboard supports 16 gb Max. Will upgrade the graphics cards to GTX 1070 /1060.
the i7-2600 is a decent performer to get started with, it should handle HD/1080p projects fine but might benefit with proxies for 4k material. 16gb of memory and a gtx 1050 ti would be a normal config for HD/1080p with that cpu. it would require some special workflow, like gpu based plugins, to need a gtx 1060 or higher.
if you haven't already, you should check the power supply for which pcie power leads it has for a video card. if there aren't any available, there are some gtx 1050 ti cards that don't need any power cables.
