8 Replies Latest reply on Feb 5, 2017 7:20 AM by Kukurykus
    Getting a value instead of setting a value
    simene49649793 Level 1
      I'm still trying to learn my way through AM code in Photoshop, and to be honest it's still 99% guessing
      So with the script listener it's pretty easy to create most of the stuff I want, that goes for everything that involves setting values. I was wondering if anyone could please explain how you go about getting values?
      The example-code below will disable "Hyphenate" on the selected text layer
      var desc1 = new ActionDescriptor();
      var actionRef = new ActionReference();
      actionRef.putProperty(charIDToTypeID("Prpr"), stringIDToTypeID("paragraphStyle"));
      actionRef.putEnumerated(charIDToTypeID("TxLr"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt"));
      desc1.putReference(charIDToTypeID("null"), actionRef);
      var desc2 = new ActionDescriptor();
      desc2.putBoolean(stringIDToTypeID("hyphenate"), false);
      desc1.putObject(charIDToTypeID("T   "), stringIDToTypeID("paragraphStyle"), desc2);
      executeAction(charIDToTypeID("setd"), desc1, DialogModes.NO);
      How would you go about changing this code so that it retrieves the "Hyphenate" value of the selected text layer instead?
        • 1. Re: Getting a value instead of setting a value
          for an example
          function getBrushFeatures (){
            //A Brush tool must be the current tool
              if (!app.toolSupportsBrushes(app.currentTool)) selectBrush();  //CC 2014
              var ref = new ActionReference();
              ref.putEnumerated( charIDToTypeID("capp"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
              var appDesc = executeActionGet(ref);
              var toolDesc = appDesc.getObjectValue(stringIDToTypeID('currentToolOptions'));
              var brushDesc = toolDesc.getObjectValue(stringIDToTypeID('brush'));
              var currDiameter = brushDesc.getDouble(stringIDToTypeID('diameter'));
              var currHardness = brushDesc.getDouble(stringIDToTypeID('hardness'));
              var currAngle = brushDesc.getDouble(stringIDToTypeID('angle'));
              var currRoundness = brushDesc.getDouble(stringIDToTypeID('roundness'));
              var currSpacing = brushDesc.getDouble(stringIDToTypeID('spacing'));
              var currFlipy = brushDesc.getBoolean(stringIDToTypeID('flipY'));
              var currFlipx = brushDesc.getBoolean(stringIDToTypeID('flipX'));
              var currentFeatures = new Array( currDiameter, currHardness, currAngle, currRoundness, currSpacing, currFlipy, currFlipx );
              return currentFeatures
          • 2. Re: Getting a value instead of setting a value
            Thank you JJMack, but in my case it says that the requestet property does not exist when I try to get the "hyphenate" value
            var actionDes = executeActionGet(actionRef);
            actionDes.getBoolean(stringIDToTypeID("hyphenate"));
            When getting the keys contained in the descriptor I only get these:
            name,color,visible,mode,opacity,layerID,itemIndex,count,preserveTransparency,layerFXVisibl e,globalAngle,background,textKey,layerSection,layerLocking,group,targetChannels,visibleCha nnels,channelRestrictions,fillOpacity,hasUserMask,hasVectorMask,proportionalScaling,layerK ind,hasFilterMask,userMaskDensity,userMaskFeather,vectorMaskDensity,vectorMaskFeather,boun ds,boundsNoEffects,useAlignedRendering,generatorSettings,keyOriginType,fillEnabled,animati onProtection,artboard,artboardEnabled
            Se neither "paragraphStyle" or "hyphenate" seems to be available from my ActionDescriptor?
            • 3. Re: Getting a value instead of setting a value
              pixxxel schubser MVP & Adobe Community Professional
              simene49649793
              the following is only „DOM-Code“ and not AM-Code.
              But perhaps it helps a little.
              var doc = activeDocument;
              if (doc.activeLayer.kind  == LayerKind.TEXT) {
                  var myText = doc.activeLayer.textItem;
                  alert(myText.contents)
                  alert(myText.hyphenation)
              Have fun
              • 4. Re: Getting a value instead of setting a value
                pixxxel schubse: Thank you, that's the way I have been doing it until now. The reason I am asking about AM-code is that DOM-code is so slow compared, so I'm trying to figure out how to understand AM-code
                • 5. Re: Getting a value instead of setting a value
                  I gotta ask though, does anybody actually understand AM-code? Like in the way that you can write AM-code in a logical sense without having to clip out parts from example-codes? Even though I'm comfortable with Java and Python, I just can't seem to wrap my mind around AM-code Even with the example provided by JJMack I don't get it, I really do try, but I feel like I'm hitting the wall on every single approach I take
                  • 6. Re: Getting a value instead of setting a value
                    Kukurykus Adobe Community Professional
                    simene49649793 How did you get keys continaed in descriptor (blue font) ?
                    I tried this but is there any way to set a length of  my loop (I had to set infinite and then to catch error when it's ending)
                    function cTT(v) {return charIDToTypeID(v)}; function sTT(v) {return stringIDToTypeID(v)}
                    (ref = new ActionReference()).putEnumerated(sTT('textLayer'), sTT('ordinal'), sTT('targetEnum'))
                    dsc = executeActionGet(ref); for(i = 0;; i++) try{alert(typeIDToStringID(dsc.getKey(i)))} catch(errEnd) {}
                    • 7. Re: Getting a value instead of setting a value
                      Kukuryku: I did it like this:
                      // Create a variable to store keys contained in the descriptor
                      containedKeys = new Array;
                      // For each key in the Action Descriptor
                      for(itmIndex = 0; itmIndex < actionDes.count; itmIndex++)
                        // Get the current key, and store it as a StringID
                        containedKeys.push(typeIDToStringID(actionDes.getKey(itmIndex))));
                      • 8. Re: Getting a value instead of setting a value
                        Thank You, I also changed last version of my script, and did new one in DOM:
                        $.level = 0, function cTT(v) {return charIDToTypeID(v)}; function sTT(v) {return stringIDToTypeID(v)}
                        for(dsc = executeActionGet(ref), txt = '', i = 0; i < dsc.count; i++) txt += typeIDToStringID(dsc.getKey(i)) + '\n'
                        alert(txt)
                        txt = ''; for(i in activeDocument.activeLayer.textItem) txt += i + '\n'; alert(txt)
                        As you see there are twice more positions :/
                        so if DOM is based on ActionManager I guess, why aren't they available from AM too (just only 30)?
