1 Reply Latest reply on Feb 2, 2017 3:04 PM by Roei Tzoref
    current time indicator...2 questions.
    andig4379031
      Hi i have 2 questions that I hope are down to my stupidity and newness.
      1 when i preview by pressing the space bar the preview is fine but the when the real time indicator gets to the right of the screen it just keeps going and i can't see it anymore...i would have thought or hope that the time line would scroll along so that i could see the layers at the actual point that the preview is at
      2. when i use RAM preview, the real time indicator just doesn't move at all...preview is fine but its impossible to see the layers and time line that matches the current part of the preview.
      After effects CC 12.1.0.168
      OS 10.12.2
      thanks for your help
        • 1. Re: current time indicator...2 questions.
          Roei Tzoref Adobe Community Professional
          OS 10.12.2
          you are using Sierra which is not supported for your Ae version. the only fully supported version for Sierra is CC2017 aka 14.x. this could or could not be related to your problem. just bare that in mind.
          you should update your software to 12.2.1 to make sure you are with the least buggy version.
          about your preview questions.
          in CC 12.x your spacebar and Numpad 0 preview will play to the entire work area. by default the work area is set to the duration of your composition but you can change that. you can drag the handles on the edges
          or use the shortcuts B and N
          you can also use the handy "From Current Time" checkbox
          this will preview your composition from where your CTI is.
          it appears you are very new to the software. Ae is not intuitive. you should spend a good amount of time here first: After Effects tutorials
          if you want to explore a feature, just type the name in the search filed the upper right corner of your Ae interface and press Enter. here's what you get when you type "Preview": Search results
