5 Replies Latest reply on Feb 4, 2017 3:05 PM by vangroover
    Suddenly android build Fail after updated to cli-6.5.0
    ihernandezp
      Please Help! I don't understand why my app don't bulid.
      This is my app ID: 2205502
      This is the output:
      FAILED
      FAILURE: Build failed with an exception.
      * What went wrong:
      Execution failed for task ':processDebugResources'.
      > com.android.ide.common.process.ProcessException: Failed to execute aapt
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 2.128 secs
      Error: /project/gradlew: Command failed with exit code 1 Error output:
      Note: Some input files use or override a deprecated API.
      Note: Recompile with -Xlint:deprecation for details.
      /project/build/intermediates/manifests/full/debug/AndroidManifest.xml:32:23-37: AAPT: No resource found that matches the given name (at 'icon' with value '@drawable/icon').
      Warning: AndroidManifest.xml already defines debuggable (in http://schemas.android.com/apk/res/android); using existing value in manifest.
      /project/build/intermediates/manifests/full/debug/AndroidManifest.xml:29: error: Error: No resource found that matches the given name (at 'icon' with value '@drawable/icon').
      * What went wrong:
      * Try:
        at ChildProcess.whenDone (/project/cordova/node_modules/cordova-common/src/superspawn.js:169:23)
        at emitTwo (events.js:106:13)
        at ChildProcess.emit (events.js:191:7)
        at maybeClose (internal/child_process.js:877:16)
        at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
