7 Replies Latest reply on Mar 15, 2017 9:00 AM by AdamReed
    Tried to build app but came up with error
    Sunny Pek Level 1
      Edit my code and re-uploaded the code (deleted app and uploaded new .zip) but encountered an error. Was working fine yesterday but today I received this error.
      App id: com.keppel.onekeppel
      Build Date: 2017-02-03 02:50:27 +0000
      PLUGIN OUTPUT
      Fetching plugin "cordova-plugin-whitelist@1" via npm
      Installing "cordova-plugin-whitelist" at "1.3.1" for android
        This plugin is only applicable for versions of cordova-android greater than 4.0. If you have a previous platform version, you do *not* need this plugin since the whitelist will be built in.
      COMPILE OUTPUT
      Subproject Path: CordovaLib
      Configuration on demand is an incubating feature.
      Incremental java compilation is an incubating feature.
      :preBuild UP-TO-DATE
      :preDebugBuild UP-TO-DATE
      :checkDebugManifest
      :CordovaLib:preBuild UP-TO-DATE
      :CordovaLib:preDebugBuild UP-TO-DATE
      :CordovaLib:checkDebugManifest
      :CordovaLib:prepareDebugDependencies
      :CordovaLib:compileDebugAidl
      :CordovaLib:compileDebugNdk UP-TO-DATE
      :CordovaLib:compileLint
      :CordovaLib:copyDebugLint UP-TO-DATE
      :CordovaLib:mergeDebugShaders
      :CordovaLib:compileDebugShaders
      :CordovaLib:generateDebugAssets
      :CordovaLib:mergeDebugAssets
      :CordovaLib:mergeDebugProguardFiles
      :CordovaLib:packageDebugRenderscript UP-TO-DATE
      :CordovaLib:compileDebugRenderscript
      :CordovaLib:generateDebugResValues
      :CordovaLib:generateDebugResources
      :CordovaLib:packageDebugResources
      :CordovaLib:processDebugManifest
      :CordovaLib:generateDebugBuildConfig
      :CordovaLib:processDebugResources
      :CordovaLib:generateDebugSources
      :CordovaLib:incrementalDebugJavaCompilationSafeguard
      :CordovaLib:compileDebugJavaWithJavac
      :CordovaLib:compileDebugJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      Note: Some input files use or override a deprecated API.
      Note: Recompile with -Xlint:deprecation for details.
      :CordovaLib:processDebugJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForDebug
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug
      :CordovaLib:mergeDebugJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForDebug
      :CordovaLib:transformNative_libsWithSyncJniLibsForDebug
      :CordovaLib:bundleDebug
      :prepareProjectCordovaLibUnspecifiedDebugLibrary
      :compileDebugAidl
      :mergeDebugResources
      :processDebugResources/project/build/intermediates/manifests/full/debug/AndroidManifest.xm l:25:23-37: AAPT: No resource found that matches the given name (at 'icon' with value '@drawable/icon').
      Warning: AndroidManifest.xml already defines debuggable (in http://schemas.android.com/apk/res/android); using existing value in manifest.
      /project/build/intermediates/manifests/full/debug/AndroidManifest.xml:22: error: Error: No resource found that matches the given name (at 'icon' with value '@drawable/icon').
      FAILED
      FAILURE: Build failed with an exception.
      * What went wrong:
      Execution failed for task ':processDebugResources'.
      > com.android.ide.common.process.ProcessException: Failed to execute aapt
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 1.704 secs
      Error: /project/gradlew: Command failed with exit code 1 Error output:
      /project/build/intermediates/manifests/full/debug/AndroidManifest.xml:25:23-37: AAPT: No resource found that matches the given name (at 'icon' with value '@drawable/icon').
      * What went wrong:
      * Try:
        at ChildProcess.whenDone (/project/cordova/node_modules/cordova-common/src/superspawn.js:169:23)
        at emitTwo (events.js:106:13)
        at ChildProcess.emit (events.js:191:7)
        at maybeClose (internal/child_process.js:877:16)
        at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
        • 1. Re: Tried to build app but came up with error
          dennisd42943628 Level 1
          I had the same error today.
          In my config.xml i was pointing to icon and screen images like this: "www/res/icon/android/drawable-ldpi-icon.png"
          I my case the folder /res/icon didn't exists. I put all the images in the correct folders and the error was gone.
          Hope this helps for you.
          • 2. Re: Tried to build app but came up with error
            Sunny Pek Level 1
            Hi dennisd42943628 thanks for your help but I have checked through my icon linking and there wasnt an issue there. It still shows me the same error.
            Thanks for you help
            • 3. Re: Tried to build app but came up with error
              VectorP Level 4
              Do you have a default icon called 'icon.png' in the root of your zip file, next to config.xml and index.html, and did you specify so in your config?
              • 4. Re: Tried to build app but came up with error
                Sunny Pek Level 1
                Okay guys I found the problem, its because of the cli update.
                To fix it, enter this - <preference name="phonegap-version" value="cli-6.3.1" /> in your config.xml under the </author> closing.
                • 5. Re: Tried to build app but came up with error
                  vangroover Adobe Employee
                  cli-6.5.0 includes an update from 5.2.2 to 6.0.2 so there will be breaking changes in there, primarily due to old plugins which access pre-6.0.0 resources etc.
                  be sure to make sure all plugins are up to date
                  • 6. Re: Tried to build app but came up with error
                    AdamReed Level 1
                    After the last cli update I get the following, after previously normal output, when I build for Android - even after removing all plugins except whitelist, which was auto-added when I added the Android platform:
                    :packageDebug
                    Daemon stopping because JVM tenured space is exhausted
                    :packageDebug FAILED
                    * What went wrong:
                    Execution failed for task ':packageDebug'.
                    > Java heap space
                    * Try:
                    BUILD FAILED
                    Total time: 2 mins 15.597 secs
                    Error: /Users/areed2/Dropbox/cordova/tmom/platforms/android/gradlew: Command failed with exit code 1 Error output:
                    * What went wrong:
                    > Java heap space
                    * Try:
                    So - what to do next? Is it possible that there is a newly introduced loop in the Cordova code? When I repeat $ cordova build --info, it terminates in exactly the same way, but without "Daemon stopping because JVM tenured space is exhausted".
                    Yes, this is a large app - the default Cordova sample app does build OK. What can I do to help find the bug?
                    • 7. Re: Tried to build app but came up with error
                      AdamReed Level 1
                      Work-around: move video directories out of www. The build should check for videos under www, since they cannot be played in Android. Running out of Java heap space is a defect.
