1 Reply Latest reply on Oct 16, 2008 4:50 PM by Newsgroup_User
    switching between browsers & apps?
    robertnagle
      Hi, there, I purchased Captivate yesterday and I'm making sceencasts about a server application. I have several scenarios:
      1)switching between a desktop and web browser (and maybe a terminal).
      2)switching between 2 desktop applications
      How can this be achieved?
      Some ideas:
      create a custom size software simulation and just use Control-tab to switch between applications (will I need to create manual clicks to make sure all the actions are being recorded?)
      will I be required to have full motion recording?
      Also, is it easier to downgrade your current display to 1024x 768 or lower before you start capturing?
      I'll probably be playing around with all the settings (and I've looked at the excellent information about Captivate on the Adobe site about compressing and optimizing).
      In general though, what is the best kind of quality and video length for a capture of a web browser + 1 other desktop application I can expect with captivate 3 from a broadband connection (say 1.5-3 Mbps).
      Thanks.
        • 1. Re: switching between browsers & apps?
          Level 7
          > about a
          > Some ideas:
          > switch
          > the
          Pressing Control+Tab should be fine. Captivate should record the keypress.
          just make sure your windows are the same size. Probably simplest to set the
          screen to 1024x760 or 800x600 (if functionally appropriate) then capture
          full-screen.
          > the
          > and
          > optimizing).
          You can easily get typical Captivate content across that sort of bandwidth.
          If you use no audio, it should perform somewhere between acceptably and well
          over a modem.
          Steve
          http://twitter.com/Stevehoward999
          Adobe Community Expert: eLearning, Mobile and Devices
          European eLearning Summit - EeLS
          Adobe-sponsored eLearning conference.
          http://www.elearningsummit.eu
