1. Re: Camera RAW 9.8 Problems
Chuck Uebele Feb 3, 2017 6:51 AM (in response to ATARI2600L)1 person found this helpful -
2. Re: Camera RAW 9.8 Problems
ATARI2600L Feb 3, 2017 12:21 PM (in response to Chuck Uebele)Thanks you very much Chuck Uebele I fixed my problem
3. Re: Camera RAW 9.8 Problems
Richard Southworth Feb 3, 2017 2:27 PM (in response to ATARI2600L)I keep seeing unchecking "use graphics processor" as a fix, when it's actually a work-around. The real fix is to find the correct driver for your graphics card, so that the graphics processor operates correctly. It will increase performance for some operations.
Richard Southworth
4. Re: Camera RAW 9.8 Problems
ATARI2600L Feb 3, 2017 2:42 PM (in response to Richard Southworth)Hi Richard. When you said the correct driver you mean that I need to test some graphic drivers or will be enough with the last update graphic driver?
Thanks...
5. Re: Camera RAW 9.8 Problems
John Waller Feb 3, 2017 3:28 PM (in response to Richard Southworth)Richard Southworth wrote:
I've always understood from Adobe that the full answer is it depends on your hardware setup as well as your drivers.
The GPU feature in Lightroom is very hardware and driver dependent, partly due to its current partial implementation (Develop module only).
For some systems, it's faster e.g. 4K and 5K monitors (see Adobe's forum post below). For some, there's little change and for others it's noticeably slower due to hardware limitations.
So, for some systems, the best approach is to enable GPU support and ensure updated drivers are installed. For others, it's best to disable it regardless of drivers. It's a matter of trial and error: ensure the latest driver from the manufacturer is installed then enable/disable GPU in LR on your specific system and see how the various tools in the Develop module respond.
Adobe's lead GPU engineer for Lightroom wrote a forum post on the subject in 2015.
GPU notes for Lightroom CC (2015)
6. Re: Camera RAW 9.8 Problems
Richard Southworth Feb 3, 2017 6:57 PM (in response to John Waller)Do the Lightroom GPU support factors carry over to ACR/Photoshop? Any similar references?
Richard Southworth
7. Re: Camera RAW 9.8 Problems
John Waller Feb 4, 2017 2:17 AM (in response to Richard Southworth)According to this non-Adobe article, yes.
http://www.diyphotography.net/adobes-gpu-acceleration-is-not-that-great-after-all-yet/
"This information also applies to Camera Raw 9.0 for Photoshop/Bridge CC."
I suspect the same code is in use when the GPU is enabled in both Camera Raw and Lightroom.
8. Re: Camera RAW 9.8 Problems
Richard Southworth Feb 4, 2017 12:34 PM (in response to John Waller)The references appear to be almost two years old. It would be useful if somebody from Adobe with pertinent knowledge would comment, things may have changed with recent revisions.
I still encourage the OP to take a shot at updating video drivers, see if it makes a difference, and then report back.
Richard Southworth
9. Re: Camera RAW 9.8 Problems
John Waller Feb 4, 2017 5:22 PM (in response to Richard Southworth)1 person found this helpfulThe most current Adobe information I'm aware of is this undated FAQ and troubleshooting article
Adobe Camera Raw graphics processor (GPU) FAQ and troubleshooting
Solution 2 (of 6) advises updating the video driver
The last resort is to disable the GPU - which you astutely pointed out earlier in this thread should not be the first step. I suspect it's recommended in these forums so frequently because it provides the quickest solution for non-technical novices.
10. Re: Camera RAW 9.8 Problems
ATARI2600L Feb 5, 2017 8:09 AM (in response to ATARI2600L)Thanks you very much for all help here. I will make some test with graphic drivers to see what happen.
