3 Replies Latest reply on Feb 5, 2017 1:28 AM by Sunny Pek
    PGB cli-6.5.0 no longer builds boilerplate app (Android)
    Gordonx64
      After encountering build errors with the latest update (6.5.0), I took everything but the essentials from my config.xml file in an attempt to get a successful build, and was unable to.
      This is my config:
      <?xml version='1.0' encoding='utf-8'?>
      <widget id="com.sbeco.timesheetapp" version="1.1.0" versionCode="10" xmlns="http://www.w3.org/ns/widgets" xmlns:gap="http://phonegap.com/ns/1.0" >
          <name>Timesheet</name>
          <description>
              A internal-use only app to track employee time
          </description>
          <author email="myemail" href="mywebsite">
              Jeff Gordon
          </author>
      </widget>
      This is my build error:
      Build Date: 2017-02-03 16:39:49 +0000
      PLUGIN OUTPUT
      COMPILE OUTPUT
      Subproject Path: CordovaLib
      Configuration on demand is an incubating feature.
      Incremental java compilation is an incubating feature.
      :preBuild UP-TO-DATE
      :preDebugBuild UP-TO-DATE
      :checkDebugManifest
      :CordovaLib:preBuild UP-TO-DATE
      :CordovaLib:preDebugBuild UP-TO-DATE
      :CordovaLib:checkDebugManifest
      :CordovaLib:prepareDebugDependencies
      :CordovaLib:compileDebugAidl
      :CordovaLib:compileDebugNdk UP-TO-DATE
      :CordovaLib:compileLint
      :CordovaLib:copyDebugLint UP-TO-DATE
      :CordovaLib:mergeDebugShaders
      :CordovaLib:compileDebugShaders
      :CordovaLib:generateDebugAssets
      :CordovaLib:mergeDebugAssets
      :CordovaLib:mergeDebugProguardFiles
      :CordovaLib:packageDebugRenderscript UP-TO-DATE
      :CordovaLib:compileDebugRenderscript
      :CordovaLib:generateDebugResValues
      :CordovaLib:generateDebugResources
      :CordovaLib:packageDebugResources
      :CordovaLib:processDebugManifest
      :CordovaLib:generateDebugBuildConfig
      :CordovaLib:processDebugResources
      :CordovaLib:generateDebugSources
      :CordovaLib:incrementalDebugJavaCompilationSafeguard
      :CordovaLib:compileDebugJavaWithJavac
      :CordovaLib:compileDebugJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      Note: Some input files use or override a deprecated API.
      Note: Recompile with -Xlint:deprecation for details.
      :CordovaLib:processDebugJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForDebug
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug
      :CordovaLib:mergeDebugJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForDebug
      :CordovaLib:transformNative_libsWithSyncJniLibsForDebug
      :CordovaLib:bundleDebug
      :prepareProjectCordovaLibUnspecifiedDebugLibrary
      :compileDebugAidl
      :mergeDebugResources
      :processDebugResources/project/build/intermediates/manifests/full/debug/AndroidManifest.xm l:25:23-37: AAPT: No resource found that matches the given name (at 'icon' with value '@drawable/icon').
      Warning: AndroidManifest.xml already defines debuggable (in http://schemas.android.com/apk/res/android); using existing value in manifest.
      /project/build/intermediates/manifests/full/debug/AndroidManifest.xml:22: error: Error: No resource found that matches the given name (at 'icon' with value '@drawable/icon').
      FAILED
      FAILURE: Build failed with an exception.
      * What went wrong:
      Execution failed for task ':processDebugResources'.
      > com.android.ide.common.process.ProcessException: Failed to execute aapt
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 1.555 secs
      Error: /project/gradlew: Command failed with exit code 1 Error output:
      /project/build/intermediates/manifests/full/debug/AndroidManifest.xml:25:23-37: AAPT: No resource found that matches the given name (at 'icon' with value '@drawable/icon').
      * What went wrong:
      * Try:
        at ChildProcess.whenDone (/project/cordova/node_modules/cordova-common/src/superspawn.js:169:23)
        at emitTwo (events.js:106:13)
        at ChildProcess.emit (events.js:191:7)
        at maybeClose (internal/child_process.js:877:16)
        at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
