Anybody know what's up with the "Replace With After Effects Composition" functionality, now? We were forced to "upgrade" to CC2017 from CC2015, and Adobe seems to have managed to somehow fart this up in the new versions.
I've got a basic Premiere sequence with an audio track, an h264 .MOV reference video, and the original clips needing VFX/Motion Graphics (in original, unmodified .R3D format). There are no plugins, filters or adjustment layers on any of the footage.
I right-click on the PPro timeline and choose "Replace With After Effects Composition" in order to bounce the files to AE. When they arrive in AE, for some ridiculous reason, the linked Comp doesn't contain, y'know, the actual footage as laid out in the PPro timeline; it inexplicably contains subcomps, which, in turn, have the footage inside. If I want to work with the footage itself, rather than the subcomps, I have to go into each of the subcomps, split the video layer at the appropriate time, copy and paste it back into the original Linked Comp, and shift it into place --- a huge PITA when you're dealing with a stack of, say, 5 or 10 layers.
In CC2015 and prior, this worked as expected: the Linked Comp that opened in AE would have the raw clips, laid out properly, not subcomped for some bizarre reason.
Does anyone know how to fix this?
Thanks in advance!
I think there is some misunderstanding here.
what I am suggesting is that the precomped footage in your Ae is a result of "Scale to frame size" which is checked for your clips in premiere. right click on the clip in premiere and check
if it is indeed checked, then if you copy the clips to Ae, they will be precomped because that's the way Ae translated this feature. now, if instead you choose "set to frame size", then your footage will be also scaled to frame, but now when you copy the clips to Ae
...Copy link to clipboard
the reasons you are seeing precomps instead of clips could be because you toggled the "scale to frame size" in premiere: Re: Scale to frame size Premiere to AE behaviour?
if this is the case, you can toggle it off and and instead use "set to frame size" in premiere instead.
Ugh, you're mostly right. My settings are fine ("set to frame size" NOT toggled), but the client may have had it checked.
If I re-import the raw footage on my end, then bounce it to AE, things work properly. I'm guessing there's no way to actually fix this without re-building the entire feature from scratch with "set to frame size" toggled off, then...? The footage in the PPro seq is all scaled to 100%; the project had no need for "set to frame size"...
if it is indeed checked, then if you copy the clips to Ae, they will be precomped because that's the way Ae translated this feature. now, if instead you choose "set to frame size", then your footage will be also scaled to frame, but now when you copy the clips to Ae they won't be precomped.
More on scale to frame size vs set to frame size:
when you "scale to frame size", Premiere internally scales the footage to the frame and rasterize it - think of it as if in Ae, you scaled your footage to frame and precomped it. it's now a precomp at 100% but it really isn't the true scale value of the footage (now it makes sense it translates this way, right?).
when you "set to frame" you are really scaling the footage in it's scaling parameters. so you will see 120% or 60% as if you scaled your footage in Ae but didn't precomp it - and it also makes sense it won't need to precomp upon translation to Ae.
Nice! Right-clicking on the footage and un-checking "scale to frame size" did the trick! Thanks for your help!
Great! thanks for the feedback
