• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Split comp display
New Here ,
Feb 03, 2017 Feb 03, 2017
adobe.JPGHi. Does anyone know why this is happening? It's usually when I zoom out below 50% and happens a lot.
Views
519
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Try updating or rolling back your video driver.
Votes
Translate
Translate
Report
Report
LEGEND ,
There are currently issues with JPEGs in AE and other apps due to a bug in the new underlying core library. Convert your picture to a different image format.
Mylenium
Votes
Translate
Translate
Report
Report
Community Expert ,
Feb 04, 2017 Feb 04, 2017
If hardware acceleration and GPU drivers are not the issue, then it's what Mylenium said. In the history of After Effects there have often been problems with certain image formats and video codecs that caused problems decoding the image data that are most easily solved by simply converting the problematic source material to a different format.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Mar 03, 2017 Mar 03, 2017
Hi bnkpro,
Sorry to see you had some trouble with your footage. Did you ever solve this issue? How so? Did you transcode to a different format? Let us know.
Kevin
Votes
Translate
Translate
Report
Report
LEGEND ,
Mar 06, 2017 Mar 06, 2017
Set your composition's resolution to Auto (and/or set it manually to match your zoom level - that is, at 50% zoom, set the resolution to 1/2 and at 25% zoom, set your resolution to quarter).
Alternatively, if you go into your preferences and disable the "Hardware accelerate...panels" option, that should fix it too.
Votes
Translate
Translate
Report
Report
New Here ,
Mar 10, 2017 Mar 10, 2017
Ok, No this has not resolved. I have checked for driver updates and the problem is still happening. It is also happening with footage so the problem isn't just with JPEGs. Changing the resolution to auto seems to have helped but it's not really something you should have to do right?
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
Does changing that preference I mentioned help?
Votes
Translate
Translate
Report
Report
