11 Replies Latest reply on May 22, 2009 1:00 AM by Houfton
    Resize canvas and export as a batch?
    Level 7
      I have a collection of about 75 images for which I need each one placed on a
      resized canvas, and then exported. I'm having trouble making a pair of
      history steps that I can save to use for a batch operation. Can anyone
      help, please?
      Murray --- ICQ 71997575
      Adobe Community Expert
      (If you *MUST* email me, don't LAUGH when you do so!)
      http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
      http://www.dwfaq.com - DW FAQs, Tutorials & Resources
        • 1. Re: Resize canvas and export as a batch?
          Level 7
          Murray,
          I usually separate the horizontal and vertical images and create a
          resize command for each.
          Sounds like you need to resize them and that is all?
          alex
          > on a resized canvas, and then exported. I'm having trouble making a
          > pair of history steps that I can save to use for a batch operation. Can
          > anyone help, please?
          • 2. Re: Resize canvas and export as a batch?
            Level 7
            Not a resize - it's a recanvas. I do not want to resize any images, I just
            want to change their canvas size so that they are all the same size when the
            batch process is finished.
            "Alex Marino" <aleSxPmarA@mMt.net> wrote in message
            news:gcvsmo$p28$1@forums.macromedia.com...
            > Murray,
            > I usually separate the horizontal and vertical images and create a resize
            > command for each.
            > alex
            >> on a resized canvas, and then exported. I'm having trouble making a pair
            • 3. Re: Resize canvas and export as a batch?
              Level 7
              > placed on a resized canvas, and then exported. I'm having trouble
              > making a pair of history steps that I can save to use for a batch
              > operation. Can anyone help, please?
              Are you saying that you want to layer two images, a fixed background and
              a changing foreground? I haven't tried anything like that in Fireworks.
              If you can't find a method in FW, ImageMagick and a bit of shell
              scripting will:
              http://www.imagemagick.org/script/composite.php
              http://www.imagemagick.org/Usage/compose/
              Joe Makowiec
              http://makowiec.net/
              Email: http://makowiec.net/contact.php
              • 4. Re: Resize canvas and export as a batch?
                Level 7
                No. I'm saying I have a collection of irregularly dimensioned images (none
                wider or taller than 225Wx150H). I want them all saved on a canvas that has
                those dimensions so that I can rotate them without having screen jitters. I
                do not need to resize any of these images, only to add canvas as needed.
                "Joe Makowiec" <makowiec@invalid.invalid> wrote in message
                news:Xns9B367F73EA729makowiecatnycapdotrE@216.104.212.96...
                > scripting will:
                > Joe Makowiec
                • 5. Re: Resize canvas and export as a batch?
                  Level 7
                  So changing the canvas size of one and saving that as command doesn't
                  work? (seems like it should...)
                  alex
                  > just want to change their canvas size so that they are all the same size
                  > when the batch process is finished.
                  • 6. Re: Resize canvas and export as a batch?
                    Level 7
                    Nope - doesn't work for me. I always get a line between the two.
                    news:gcvtb3$ptv$1@forums.macromedia.com...
                    > alex
                    • 7. Re: Resize canvas and export as a batch?
                      Level 7
                      Here is what I tried:
                      Open image (500x45) > Resize Canvas to 600x600 > Go to the history panel
                      and save as a command.
                      Then invoke the command on a series of images (smaller than 600x600)
                      through File > Batch Process.
                      tell what I am missing -(it's monday don't you know ..)
                      • 8. Re: Resize canvas and export as a batch?
                        Level 7
                        OK - I had to click on the Export icon to make the command save.
                        "Murray *ACE*" <forums@HAHAgreat-web-sights.com> wrote in message
                        news:gcvtgi$q4g$1@forums.macromedia.com...
                        >> alex
                        • 9. Re: Resize canvas and export as a batch?
                          Level 7
                          The key was to click on the export command after the resize canvas step. I
                          was trying FILE | Save As, or FILE | Export, and those didn't work.
                          news:gcvtqf$ptv$2@forums.macromedia.com...
                          • 10. Re: Resize canvas and export as a batch?
                            Level 7
                            ahh .. gotcha
                            > step. I was trying FILE | Save As, or FILE | Export, and those didn't
                            > work.
                            • 11. Re: Resize canvas and export as a batch?
                              Houfton
                              I don't know what you mean about exporting the Command but I found a way round this. (I can't believe that a plain resize canvas does not work, but it does not seem to.)
                              I made a rectangle the right size (640 x 480 and white in my case) and the same resolution as the images and copied it so it was on the clipboard. I pasted that on to a prepared image (I batch resized all images to max 640 x 480 first), then: Arrange>Send to Back, Select All, Align>Centre Horizontal, Align>Centre Vertical. I saved those steps as a command. You also need to apply a Fit Canvas command next when you Batch Process (I can't remember if that is a standard Command or one I created - it only works if everything is selected.
                              Simple!
                              Richard
