5 Replies Latest reply on Mar 5, 2017 7:02 AM by pyymenta
    App not building with crosswalk plugin in my app new update
    slimkyd70099163
      Since 2weeks ago my app has been runing with crosswalk and is still running well with it. But today as I have made an update on the app with touching my config.xml.
      When i try to build in your build.phongap I get error in the build log.
      But when i remove crosswalk from the config it builds again. Build there is no problem in the first 2weeks i built with crosswalk intalled. But now I can't build my again with crosswalk so it makes me to change the crosswalk line of the config.xml and still no success.
      This is the error
      :generateArmv7DebugSources
      :incrementalArmv7DebugJavaCompilationSafeguard
      :compileArmv7DebugJavaWithJavac
      :compileArmv7DebugJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      /project/src/org/crosswalk/engine/XWalkWebViewEngine.java:47: error: XWalkWebViewEngine is not abstract and does not override abstract method evaluateJavascript(String,ValueCallback<String>) in CordovaWebViewEngine
      public class XWalkWebViewEngine implements CordovaWebViewEngine {
      Note: /project/src/org/crosswalk/engine/XWalkCordovaResourceClient.java uses or overrides a deprecated API.
      Note: Recompile with -Xlint:deprecation for details.
      1 error
      :compileArmv7DebugJavaWithJavac FAILED
      FAILURE: Build failed with an exception.
      * What went wrong:
      Execution failed for task ':compileArmv7DebugJavaWithJavac'.
      > Compilation failed; see the compiler error output for details.
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 5.302 secs
      Error: /project/gradlew: Command failed with exit code 1 Error output:
      Note: Some input files use or override a deprecated API.
      Warning: AndroidManifest.xml already defines debuggable (in http://schemas.android.com/apk/res/android); using existing value in manifest.
      1 error
      And this is my config.xml for crosswalk plugin
        <plugin name="cordova-plugin-crosswalk-webview" version="1.6.1">
          <param name="XWALK_MODE" value="lite" />
