6 Replies Latest reply on Feb 4, 2017 3:06 PM by vangroover
    People with build failed
    Sunny Pek Level 1
      People with build error similar to the one below do this.
      Add <preference name="phonegap-version" value="cli-6.3.1" /> to the config.xml under </author> closing tag.
      Cheers
      Build Date: 2017-02-03 02:50:27 +0000
      PLUGIN OUTPUT
      Fetching plugin "cordova-plugin-whitelist@1" via npm
      Installing "cordova-plugin-whitelist" at "1.3.1" for android
        This plugin is only applicable for versions of cordova-android greater than 4.0. If you have a previous platform version, you do *not* need this plugin since the whitelist will be built in.
      COMPILE OUTPUT
      Subproject Path: CordovaLib
      Configuration on demand is an incubating feature.
      Incremental java compilation is an incubating feature.
      :preBuild UP-TO-DATE
      :preDebugBuild UP-TO-DATE
      :checkDebugManifest
      :CordovaLib:preBuild UP-TO-DATE
      :CordovaLib:preDebugBuild UP-TO-DATE
      :CordovaLib:checkDebugManifest
      :CordovaLib:prepareDebugDependencies
      :CordovaLib:compileDebugAidl
      :CordovaLib:compileDebugNdk UP-TO-DATE
      :CordovaLib:compileLint
      :CordovaLib:copyDebugLint UP-TO-DATE
      :CordovaLib:mergeDebugShaders
      :CordovaLib:compileDebugShaders
      :CordovaLib:generateDebugAssets
      :CordovaLib:mergeDebugAssets
      :CordovaLib:mergeDebugProguardFiles
      :CordovaLib:packageDebugRenderscript UP-TO-DATE
      :CordovaLib:compileDebugRenderscript
      :CordovaLib:generateDebugResValues
      :CordovaLib:generateDebugResources
      :CordovaLib:packageDebugResources
      :CordovaLib:processDebugManifest
      :CordovaLib:generateDebugBuildConfig
      :CordovaLib:processDebugResources
      :CordovaLib:generateDebugSources
      :CordovaLib:incrementalDebugJavaCompilationSafeguard
      :CordovaLib:compileDebugJavaWithJavac
      :CordovaLib:compileDebugJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      Note: Some input files use or override a deprecated API.
      Note: Recompile with -Xlint:deprecation for details.
      :CordovaLib:processDebugJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForDebug
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug
      :CordovaLib:mergeDebugJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForDebug
      :CordovaLib:transformNative_libsWithSyncJniLibsForDebug
      :CordovaLib:bundleDebug
      :prepareProjectCordovaLibUnspecifiedDebugLibrary
      :compileDebugAidl
      :mergeDebugResources
      :processDebugResources/project/build/intermediates/manifests/full/debug/AndroidManifest.xm l:25:23-37: AAPT: No resource found that matches the given name (at 'icon' with value '@drawable/icon').
      Warning: AndroidManifest.xml already defines debuggable (in http://schemas.android.com/apk/res/android); using existing value in manifest.
      /project/build/intermediates/manifests/full/debug/AndroidManifest.xml:22: error: Error: No resource found that matches the given name (at 'icon' with value '@drawable/icon').
      FAILED
      FAILURE: Build failed with an exception.
      * What went wrong:
      Execution failed for task ':processDebugResources'.
      > com.android.ide.common.process.ProcessException: Failed to execute aapt
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 1.704 secs
      Error: /project/gradlew: Command failed with exit code 1 Error output:
      /project/build/intermediates/manifests/full/debug/AndroidManifest.xml:25:23-37: AAPT: No resource found that matches the given name (at 'icon' with value '@drawable/icon').
      * What went wrong:
      * Try:
        at ChildProcess.whenDone (/project/cordova/node_modules/cordova-common/src/superspawn.js:169:23)
        at emitTwo (events.js:106:13)
        at ChildProcess.emit (events.js:191:7)
        at maybeClose (internal/child_process.js:877:16)
        at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
