8 Replies Latest reply on Feb 9, 2017 7:07 AM by interactivePixels
    Composition Window Preview not showing anything
    interactivePixels Level 1
      Hi folks,
      i am struggling with the following problem:
      Regardless of the version of Ae (i run both the final CC2015 Version, as well as the most recent CC2017 update) - after trying to preview a composition in my project, the composition window becomes empty and doesn't display anything (see images attached). After that, no matter what composition i open, it all remains blank, when scrubbing through the timeline and when previewing. When i try to quit Ae after that, it becomes unresponsive - i can't exit it other than killing the process in the task manager..
      I have tried the following:
      - purge cache/image memory
      - import project into a new project
      - open project in different versions of AE
      After seeing similar problems in other threads (with none of the "solutions" helping) let me assure the following:
      - it is not a magnification or zooming issue, when i start the preview i can see everything, the preview is just killed after that rightaway
      - the CTI is at a point in time where things should be visible
      - my preview mode is "Off (Final Quality)" and no matter what i change it to, the problem remains
      - i AM using the most recent versions and drivers, yes i do.
      I'm running Ae on a Windows 7 Pro machine with 32GB of Ram and a GeForce GTX1070 with the most recent drivers, updates, etc.
      Any help is greatly appreciated, since i can't continue to work this way..
      Kindest regards
      iPixxels
