• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
10
Changed Composition Size - Scale All Layers to Match?
New Here ,
Feb 04, 2017 Feb 04, 2017
Hello,
I am trying to repurpose an After Effects file for another project. The original composition was set at 1080x720 in the AE file I received, but I had to change the size to 1920x1080 for the new project.
I've already changed the size of the composition using the "Composition Settings" but I am wondering if there is a way to scale/resize all of my layers to correspond to my new composition size of 1920x1080 without having to do a ton of repositioning. There are a lot of elements and transitions that I would like to keep, and I'm hoping I don't have to recreate too much of that.
I know I am basically moving from a 3:2 (1080x720) to a 16:9 (1920x1080) aspect ratio, so I might be out of luck here but I wanted to get thoughts of some others.
Is there a quick and semi-painless way to resize my layers to fit the new composition size, or do I have to resize each individually because the pixel ratio is different?
TOPICS
How to
Views
239.4K
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Feb 04, 2017 Feb 04, 2017
1. select your 1080x720 composition in the project panel
2. go to file->scripts->scale composition
3. select "new comp width" and change it from 1080 to 1920 and click "scale"
4. in the composition settings change the composition height from 1280 to 1080
Votes
Translate
Translate
LEGEND ,
Votes
Translate
Translate
Report
Report
New Here ,
Thank you very much for your help!
Votes
Translate
Translate
Report
Report
LEGEND ,
You're welcome Ben!
Votes
Translate
Translate
Report
Report
New Here ,
Dec 21, 2018 Dec 21, 2018
Thank You!
Votes
Translate
Translate
Report
Report
Community Beginner ,
Oct 14, 2019 Oct 14, 2019
Dude, thanks a lot, It worked
Votes
Translate
Translate
Report
Report
New Here ,
Dec 03, 2019 Dec 03, 2019
Thank you!
Votes
Translate
Translate
Report
Report
New Here ,
Jan 03, 2020 Jan 03, 2020
Thank you! Huge help!
Votes
Translate
Translate
Report
Report
Feb 25, 2020 Feb 25, 2020
When I use the script to scale a composition from HD to 4k, it appears that it worked in AE, but when I export as MOGRT to premiere pro, the canvas is now 4k but the elements are in their original HD locations. How can I scale everything to 4k without having to readjust everything?
Votes
Translate
Translate
Report
Report
Mar 18, 2020 Mar 18, 2020
Thank you so much! You saved my life!
Votes
Translate
Translate
Report
Report
New Here ,
May 10, 2021 May 10, 2021
(I was going crazy... ) BIG thanks!!
Votes
Translate
Translate
Report
Report
Oct 10, 2021 Oct 10, 2021
This does not work anymore with After Effects 2020.
The scale comp is always auto jumping to 1440x1080 instead of 1920, and changing height in Comp Settings just adds more blace space.
This is not fixed in 2021, in need of help still.
Votes
Translate
Translate
Report
Report
New Here ,
Nov 02, 2021 Nov 02, 2021
damn why i didn't find that earlier? you made my life easier
Votes
Translate
Translate
Report
Report
New Here ,
May 09, 2022 May 09, 2022
bless you! It worked
Votes
Translate
Translate
Report
Report
New Here ,
Jun 14, 2022 Jun 14, 2022
Worked like a charm!
Votes
Translate
Translate
Report
Report
Oct 04, 2022 Oct 04, 2022
Does this alter the resolution at all? I know making a new comp to 1080 and bringing in a comp with a smaller ratio seems to compromise the resolution when I export––everything looks slightly fuzzy.
Votes
Translate
Translate
Report
Report
New Here ,
Dec 02, 2022 Dec 02, 2022
thanks
Votes
Translate
Translate
Report
Report
Dec 03, 2022 Dec 03, 2022
I did that but the resulting images (layers) are now pixelated, like low resolution. I did a logo animation from an imported Illustrator file, with many layers.
Is there a way to preserve the quality or maybe reload the file to new size?
Votes
Translate
Translate
Report
Report
New Here ,
Dec 15, 2022 Dec 15, 2022
Hi Roei,
for me unfortunately the composition rezied not only in higth but also in width, even if I checked only "new composition high"t and in the origiNal composition I unchecked the "proportional box". What do I have to do to only resize either in height or in width? Thank you.
Votes
Translate
Translate
Report
Report
New Here ,
Oct 19, 2023 Oct 19, 2023
Man, You are awesome. I was stuck in a project and this magically worked for me. Thanks a ton!
Votes
Translate
Translate
Report
Report
Feb 19, 2024 Feb 19, 2024
Thank you!
Votes
Translate
Translate
Report
Report
New Here ,
Mar 28, 2024 Mar 28, 2024
LATEST
Thank you!
Votes
Translate
Translate
Report
Report
New Here ,
Dec 01, 2018 Dec 01, 2018
This just saved my life
Votes
Translate
Translate
Report
Report
New Here ,
Apr 24, 2019 Apr 24, 2019
Thank you
Votes
Translate
Translate
Report
Report
Apr 08, 2020 Apr 08, 2020
Hi!
Im very new to after effects (im a graphic designer, heavy indesigner user) and ive got a similar problem to the person who started this thread. I realise its an old thread but I wondered if anyone could help. I need to resize an multi layer animation in order to repurpose it. It was originally made to be a web banner, now it needs to fit a 1920x1080 screen. I tried the fix suggested in tis thread but it doesnt seem to have worked and I cannot figure why. It looks like the actual stage has not changed. As ive said, im not the best in AE! Can anyone help?
Votes
Translate
Translate
Report
Report
