4 Replies Latest reply on Feb 24, 2017 3:11 AM by Akash Sharma
    CC and Sniffer only detects one GPU at a time
    NCARalph
      I'm on Windows 10 with CC 2017. I've got two GPU's the built in Intel HD Graphics 530 and a separate AMD Radeon R9 270. If I use both GPUs, with a monitor plugged into each, sniffer.exe never returns any GPU information.
      Other software, notably Vegas Pro, detect both GPUs and can use either.
      Both running:
      C:\Program Files\Adobe\Adobe Photoshop CC 2017>sniffer
      Tester="Photoshop"
      snifferStart="2017-02-04_13:50:40"
      AIFCoreInitialized=1
      AIFOGLInitialized=1
      OGLContextCreated=1
      Nothing else.
      However, if I disable either card, sniffer detects it and reports all the information.
      Intel Only:
      Note this shows two GPU drivers, the Intel one and Microsoft Basic Render Driver. What's going on is that when I disable the AMD driver, the Microsoft Basic Render Driver apparently is automatically started and controls the AMD card. Even though the AMD is "disabled" the monitor it's connected to is operational.
      Tester="Photoshop"
      snifferStart="2017-02-04_13:49:55"
      AIFOGLInitialized=1
      OGLContextCreated=1
      NumGLGPUs=2
      glgpu[0].GLVersion="4.1"
      glgpu[1].GLVersion="4.1"
      glgpu[0].IsIntegratedGLGPU=0
      glgpu[1].IsIntegratedGLGPU=0
      glgpu[0].GLMemoryMB=1024
      glgpu[1].GLMemoryMB=0
      glgpu[0].GLName="Intel(R) HD Graphics 530"
      glgpu[1].GLName="Microsoft Basic Render Driver"
      glgpu[0].GLVendor="Intel"
      glgpu[1].GLVendor="Intel"
      glgpu[0].GLVendorID=32902
      glgpu[1].GLVendorID=5140
      glgpu[0].GLDriverVersion="21.20.16.4574"
      glgpu[1].GLDriverVersion="?"
      glgpu[0].GLRectTextureSize=16384
      glgpu[1].GLRectTextureSize=16384
      glgpu[0].GLRenderer="Intel(R) HD Graphics 530"
      glgpu[1].GLRenderer="Intel(R) HD Graphics 530"
      glgpu[0].GLRendererID=6418
      glgpu[1].GLRendererID=140
      glgpu[0].HasGLNPOTSupport=1
      glgpu[1].HasGLNPOTSupport=1
      glgpu[0].GLDriver="igdumdim64,igd10iumd64,igd10iumd64,igd12umd64,igdumdim32,igd10iumd32,ig d10iumd32,igd12umd32"
      glgpu[1].GLDriver="?"
      glgpu[0].GLDriverDate="20161223000000.000000-000"
      glgpu[1].GLDriverDate="?"
      glgpu[0].CanCompileProgramGLSL=1
      glgpu[1].CanCompileProgramGLSL=1
      glgpu[0].GLFrameBufferOK=1
      glgpu[1].GLFrameBufferOK=1
      gputag.GL_SHADING_LANGUAGE_VERSION=35724
      glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.30 - Build 21.20.16.4574"
      glgpu[1].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.30 - Build 21.20.16.4574"
      gputag.GL_FRAGMENT_PROGRAM_ARB=34820
      gputag.GL_MAX_PROGRAM_INSTRUCTIONS_ARB=34977
      glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1447 ]
      glgpu[1].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1447 ]
      gputag.GL_MAX_TEXTURE_UNITS=34018
      glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
      glgpu[1].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
      gputag.GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS=35661
      glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
      glgpu[1].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
      gputag.GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS=35660
      glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
      glgpu[1].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
      gputag.GL_MAX_TEXTURE_IMAGE_UNITS=34930
      glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
      glgpu[1].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
      gputag.GL_MAX_DRAW_BUFFERS=34852
      glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
      glgpu[1].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
      gputag.GL_MAX_VERTEX_UNIFORM_COMPONENTS=35658
      glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
      glgpu[1].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
      gputag.GL_MAX_FRAGMENT_UNIFORM_COMPONENTS=35657
      glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
      glgpu[1].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
      gputag.GL_MAX_VARYING_FLOATS=35659
      glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[64]
      glgpu[1].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[64]
      gputag.GL_MAX_VERTEX_ATTRIBS=34921
      glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
      glgpu[1].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
      gputag.AIF::OGL::GL_ARB_VERTEX_PROGRAM=69
      glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
      glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
      gputag.AIF::OGL::GL_ARB_FRAGMENT_PROGRAM=27
      glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
      glgpu[1].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
      gputag.AIF::OGL::GL_ARB_VERTEX_SHADER=70
      glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
      glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
      gputag.AIF::OGL::GL_ARB_FRAGMENT_SHADER=28
      glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
      glgpu[1].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
      gputag.AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT=81
      glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
      glgpu[1].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
      gputag.AIF::OGL::GL_ARB_TEXTURE_RECTANGLE=58
      glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
      glgpu[1].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
      gputag.AIF::OGL::GL_ARB_TEXTURE_FLOAT=53
      glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
      glgpu[1].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
      gputag.AIF::OGL::GL_ARB_OCCLUSION_QUERY=37
      glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
      glgpu[1].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
      gputag.AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT=68
      glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
      glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
      gputag.AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD=47
      glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=0
      glgpu[1].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=0
      NumCLGPUs=1
      clgpu[0].CLPlatformVersion="2.0 "
      clgpu[0].CLDeviceVersion="2.0 "
      clgpu[0].IsIntegratedCLGPU=1
      clgpu[0].CLMemoryMB=6502
      clgpu[0].CLName="Intel(R) HD Graphics 530"
      clgpu[0].CLVendor="Intel(R) Corporation"
      clgpu[0].CLVendorID=32902
      clgpu[0].CLDriverVersion="21.20.16.4574"
      clgpu[0].CUDASupported=0
      clgpu[0].CLBandwidth=2.63438e+10
      clgpu[0].CLCompute=186.922
      NumNativeGPUs=0
      snifferEnd="2017-02-04_13:49:56"
      AMD Only
      Tester="Photoshop"
      snifferStart="2017-02-04_14:14:21"
      AIFOGLInitialized=1
      OGLContextCreated=1
      NumGLGPUs=1
      glgpu[0].GLMemoryMB=2048
      glgpu[0].GLName="AMD Radeon (TM) R9 200 Series"
      glgpu[0].GLVendor="ATI Technologies Inc."
      glgpu[0].GLVendorID=4098
      glgpu[0].GLDriverVersion="21.19.413.0"
      glgpu[0].GLRenderer="AMD Radeon (TM) R9 200 Series"
      glgpu[0].GLRendererID=26641
      glgpu[0].GLDriver="aticfx64.dll,aticfx64.dll,aticfx64.dll,amdxc64.dll,aticfx32,aticfx32,at icfx32,amdxc32,atiumd64,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiu md6a.cap,atitmm64"
      glgpu[0].GLDriverDate="20170125000000.000000-000"
      glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50"
      glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[2147 483647]
      glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[16384]
      glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[16384]
      glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[128]
      glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[29]
      glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
      NumCLGPUs=1
      clgpu[0].CLPlatformVersion="2.0 AMD-APP (2236.10)"
      clgpu[0].CLDeviceVersion="1.2 AMD-APP (2236.10)"
      clgpu[0].IsIntegratedCLGPU=0
      clgpu[0].CLMemoryMB=2048
      clgpu[0].CLName="Pitcairn"
      clgpu[0].CLVendor="Advanced Micro Devices, Inc."
      clgpu[0].CLVendorID=4098
      clgpu[0].CLDriverVersion="2236.10"
      clgpu[0].CLBandwidth=1.38808e+11
      clgpu[0].CLCompute=1078.71
      NumNativeGPUs=0
      snifferEnd="2017-02-04_14:14:22"
      Message was edited by: Ralph Brown to explain what's happening with the Microsoft Basic Render Driver.
