5 Replies Latest reply on Dec 5, 2017 4:03 AM by fenjas29325284
    Liquify tool in CC
    carmenm71785802
      Hoping there is a fix. I've been editing all morning and using liquify on most. No problems, I open up the next photo and all of the sudden liquify is weird. I have all these tools on the left but I can't for the life of me figure out how to get to just normal brush liquify. Any help or advise appreciated!
      TIA!
        • 1. Re: Liquify tool in CC
          fenjas29325284 Level 5
          Menu Filter?
          Fenja
          • 2. Re: Liquify tool in CC
            Benjamin Root MVP & Adobe Community Professional
            You want the Forward Warp Tool.
            • 3. Re: Liquify tool in CC
              italosan Adobe Community Professional
              If a type layer or a shape layer is selected, you must rasterize the layer before proceeding, making the type or shape editable by the Liquify filter. To distort type without rasterizing the type layer, use the Warp options for the Type tool.
              • Select the layer you want to distort. To change only part of the current layer, select that area.
              • Choose Filter > Liquify.
              Prerequisite: Enable the graphics processor
              As a prerequisite to using Face-aware Liquify functionality, ensure that the graphics processor is enabled in your Photoshop preferences.
              1. Choose Edit > Preferences > Performance.
              2. In the Graphics Processor Settings area, select Use Graphics Processor.
              3. Click Advanced Settings. Ensure that Use Graphics Processor To Accelerate Computation is selected.
              4. Click OK.
              These settings are enabled by default when you launch Photoshop for the first time. If you have questions regarding GPU usage in Photoshop, consult this document.
              Distortion tools
              Several tools in the Liquify dialog box distort the brush area when you hold down the mouse button or drag. The distortion is concentrated at the center of the brush area, and the effect intensifies as you hold down the mouse button or repeatedly drag over an area.
              Forward Warp tool
              Pushes pixels forward as you drag.
              Note:Shift-click with the Warp tool, the Push Left tool, or the Mirror tool to create the effect of dragging in a straight line from the previous point you clicked.
              Reconstruct tool
              Reverses the distortion you’ve already added, as you hold down the mouse button and drag.
              Twirl Clockwise tool
              Rotates pixels clockwise as you hold down the mouse button or drag. To twirl pixels counterclockwise, hold down Alt (Windows) or Option (Mac OS) as you hold down the mouse button or drag.
              Pucker tool
              Moves pixels toward the center of the brush area as you hold down the mouse button or drag.
              Bloat tool
              Moves pixels away from the center of the brush area as you hold down the mouse button or drag.
              Push Left tool
              Moves pixels to the left when you drag the tool straight up (pixels move to the right if you drag down). You can also drag clockwise around an object to increase its size, or drag counterclockwise to decrease its size. To push pixels right when you drag straight up (or to move pixels left when you drag down), hold down Alt (Windows) or Option (Mac OS) as you drag.
              Distortion tool options
              In the tool options area of the dialog box, set the following options:
              Brush Size
              Sets the width of the brush you’ll use to distort the image.
              Brush Density
              Controls how a brush feathers at the edge. An effect is strongest in the center of the brush and lighter at the edge.
              Brush Pressure
              Sets the speed at which distortions are made when you drag a tool in the preview image. Using a low brush pressure makes changes occur more slowly, so it’s easier to stop them at exactly the right moment.
              Brush Rate
              Sets the speed at which distortions are applied when you keep a tool (such as the Twirl tool) stationary in the preview image. The higher the setting, the greater the speed at which distortions are applied.
              Stylus Pressure
              Uses pressure readings from a stylus tablet. (This option is available only when you are working with a stylus tablet.) When selected, the brush pressure for the tools is the stylus pressure multiplied by the Brush Pressure value.
              • 4. Re: Liquify tool in CC
                erikao76871328
                I have Adobe Photoshop CC as the monthly $9.99 option. I do not have the entire liquify selection drop down menu - no froward warp, no liquify, no pucker, etc. Do I have to purchase these tools somewhere or enable them somehow within photoshop?
                Need answer ASAP if anyone out there is watching this.
                THANKS!
                e
                • 5. Re: Liquify tool in CC
                  There isn't a liquify selection dropdown menu. The Liquify filter has a window of its own with a toolbar on the left edge.
                  Fenja
