4 Replies Latest reply on Feb 8, 2017 4:43 PM by frogadelic
    Particle Systems II Effect Issue
    frogadelic
      Hi Community,
      I ran into a problem using the Particle Systems II Effect in After Effects CC v2017
      I have a 2D jpeg as a layer, and I've been trying to add a layer of particles (to look like floating dust) on top. However, when I use the Particle Systems II Effect, I run into this problem:
      I followed this youtube tutorial (Dust Particles Effect in After Effects - YouTube) step by step, so I what I did was create the solid color (black) layer, then made an adjustment layer, added the Particle Systems II Effect to the adjustment layer, and tailored it to what I wanted it to look like. But when I select the adjustment layer, then go to Layer>Pre-Compose>Move All Attributes to New Composition, the result is the effect disappears, and all that shows is the solid layer. What am I doing wrong here? I'm just trying to get this effect to overlay another layer. Please help me.
        • 1. Re: Particle Systems II Effect Issue
          You don't have to make the layer an adjustment layer. It never says anything of the sort in the tutorial even.
          Mylenium
          • 2. Re: Particle Systems II Effect Issue
            frogadelic Level 1
            Hi Mylenium,
            At 3:00 in the video, he does mention to create an adjustment layer. At 3:21, he says to drag the Particle Systems II Effect onto the adjustment layer.
            Either way, is there some different way I can use this effect to go on top of a jpeg, and still have that jpeg show through?
            • 3. Re: Particle Systems II Effect Issue
              Paul Michelle Adobe Community Professional
              The dudes workflow doesn't make much sense.  Even his explanation of why he added that solid didn't make sense.  The reason he  couldn't see the solid when he created the effect was BECAUSE he was using an adjustment layer. Adjustment layer apply their properties to the entire layer stack underneath them.  There's absolutely NO reason to use an adjustment layer in that situation.  He obviously does not understand how adjustment layers work.
              So that's why he couldn't see his grey solid.  The reason he was seeing a black matte (instead of transparency) is because he does not have transparency enabled in his project.  If he would have just created another solid on top of the grey solid (instead of the adjustment layer) and applied the effect to that, then he would have been able to see the grey solid.  Bottom line.  He doesn't really know what he's doing. at least in this particular (no pun intended) situation.
              All you need to do is create a solid above your jpeg (the color does not matter) and apply the particle system effect.  That's it.  Once you duplicate it, if you want you can pre compose the two particle layers just for organizational purposes but it's not even necessary.  You just had the unfortunate luck of stumbling onto a poopy Youtube tutorial.
              Oh, one last thing is that we should all go to that tutorial and give it big fat 'thumbs down'
              • 4. Re: Particle Systems II Effect Issue
                frogadelic Level 1
                Thank you Gutter-Fish, for clarifying! Your explanation worked perfectly, I appreciate your advice!
