6 Replies Latest reply on Feb 6, 2017 11:06 AM by maker_ryan
    Memory leak? Ch crashed and said system out of memory, now project won't reopen
    maker_ryan
      Uh oh. So, on Friday I was working in Character Animator and my system gave a memory error, asking me to Force Quit some programs.
      Now, the project I was working on at the time won't reopen, and I'm getting the following error:
      Internal error code: (1033274218:1107+33) libgit2 error -3 (9/Object not found - no match for id (09c0b747099668926e7b0fce006e83d96f6d0c7d)) returned from git_blob_lookup(&blob.p, repoP.get(), &blobOid)
      It would be a gigantic bummer if I can't recover this project, as I'd put in a lot of time rigging my puppet with multiple head turn positions, body turns, Dangles, etc. So any suggestions or assistance is desperately welcome! Thank you.
      Also, memory really shouldn't be an issue for my machine unless there's a leak. My system specs are pretty robust.
      iMac (Retina 5K, 27-inch, Late 2015)
      3.2 GHz Intel Core i5
      24 GB 1867 MHz DDR3
      AMD Radeon R9 M390 2048 MB
        • 1. Re: Memory leak? Ch crashed and said system out of memory, now project won't reopen
          oksamurai Employee Moderator
          That ID stuff usually shows up if it can't find a specific file to run the project. Did you recently move or rename any files? Or are your files in a backup folder like Dropbox? If so there are a couple of existing bugs around those two. If it's possible to name everything back to its original setting or keep things in desktop folders, that might help.
          If you're able to open the project at all, go to Window > History and roll back changes - usually there's a sync or something that is the culprit of where things went wrong.
          The memory message seems strange given your specs - is the character you're working on super complex or a large file size? Can you open other template characters okay, like the default blue guy?
          • 2. Re: Memory leak? Ch crashed and said system out of memory, now project won't reopen
            maker_ryan Level 1
            The files are indeed on Dropbox. The folder structure may have changed over the weekend, which would certainly explain the error when trying to open the project. Are there other Dropbox-related bugs I should be aware of?
            As for the memory leak/issue: my character is semi-complex I guess, but I wouldn't imagine it's more complex than some of the examples you've showcased in your video series. I do basically replicate the whole puppet (body + head + hair behind head) 5x for turns, and I have 10 individual hair pieces that each have a dangle on them (so 50 pieces dangling in total, but only 10 at any given time).
            Is that over-taxing to Ch at this point?
            • 3. Re: Memory leak? Ch crashed and said system out of memory, now project won't reopen
              The Dropbox issue is this - CH makes like thousands of files, both temp and permanent, that live in your Ch Data folder. Those can change often, and all it takes is one sync error or old version on Dropbox (or any cloud service) for there to be something out of sync and cause an error. So in your case there was probably some file 3 levels deep in a weird folder somewhere that didn't save or sync correctly. We're working on solutions to this but for now your best bet is to keep it local if possible.
              Head turns + physics can definitely push things - it can be processor intensive with that many realtime calculations going on. If you can get the project to open, one thing you may want to do is hide the Dangle behavior in your scene (eyeball toggle) to speed things up when rigging, then turn it on when streaming/recording. Like my Ramirez character is similar, with head turns and lots of hair/horn dangle - and he takes a while to load and can have sluggish performance. We're working on speed issues for the future, but for now yeah - you might be starting to push the limits of what we can do. Reducing the number of dangle handles should help.
              • 4. Re: Memory leak? Ch crashed and said system out of memory, now project won't reopen
                maker_ryan Level 1
                Really good stuff oksamurai, thanks. Would I be safe(r) if I worked on a local copy while in Ch, but pushed the whole folder containing the project up to Dropbox at the end of the day (so I can then pull it down on another computer at night)?
                I'm guessing as long as I'm not working directly out of the Dropbox folder, I should be safe sync-wise.
                And as for the hair, how much of a performance difference would it make if I reduced the hair strands from 10 per view to, say, 3? I could group the hairs into 3 different layers and dangle them, and would get probably 80% of the visual effect I'm getting now, if I spread the hairs out through the 3 layers.
                Would 3 dangled elements (per 5 views) be significantly more efficient than 10?
                • 5. Re: Memory leak? Ch crashed and said system out of memory, now project won't reopen
                  Dealing with anything Dropbox / cloud saved is going to currently be risky with those mega Ch Data folders. You can do it, but I'd always save a backup local copy just to be safe.
                  Yes, 3 dangles will definitely be more efficient than 10 - that seems like it's worth a shot.
                  • 6. Re: Memory leak? Ch crashed and said system out of memory, now project won't reopen
                    maker_ryan Level 1
                    Well, I have to be able to work on my project from two different computers and I don't want to carry around a USB stick like it's 2005, so I may have to risk the cloud and just always work from a local copy.   I'll make sure to copy instead of move between local & Dropbox though so I can always fall back to the last "session" of my local copy.
                    Thanks man.
