Straight out of the UI textbook we have
// Create an empty dialog window near the upper left of the screen
var dlg = new Window("dialog", "Alert Box Builder");
dlg.frameLocation = [100,100];
dlg.show();
Half the time this works. The other half the time I get the error 22 Window does not have a constructor. Nice.
Deleting Photoshop preferences doesn't seem to make a difference. The error pops up inconstantly. I can't upgrade from CC 9.1.2 as it's work machine. Running Win 7.
As you can imagine this is just a teeny tiny bit frustrating. Is there a real solution to this? You know apart from defenestration?
Does adding some properties help?
var dlg = new Window("dialog", "Alert Box Builder", undefined, {closeButton: true});
var btn = dlg.add ('button', undefined, "I do nothing")
dlg.show();
OR This will work with either ScriptUI version. What is Photoshop CC 9.1.2????. Photoshop version 9 is CS2???? CS6 has an ACR version 9.1.1...
.frameLocation = [x,y] does not work in the new version of ScriptUI. The Dialog will be centered on your display.
runDialog(dlg)
function runDialog(dlg){
dlg.onShow = function() {
var ww = dlg.bounds.width;
var hh = dlg.bounds.height;
dlg.bounds.x = 100;
dlg.bounds.y = 100;
dlg.bounds.width = ww;
dlg.bounds.height = hh;
return dlg.show()
