5 Replies Latest reply on Feb 6, 2017 8:31 PM by Rick Gerard
    Transparency different between AE and Premiere
    darrenl60948965
      I have a lower third with a semi-transparent background that looks different once I bring it into Premiere. Tried exporting in different codecs (Animation, ProRes444) and changing alpha to straight, also tried embedding AE comp into premiere sequence. None of these methods produced the same effect as doing the overlay in AE, the transparency was lighter, portions of the background that were masked in AE became visible upon export as if the mask expanded slightly. I just want the final product to look like it does in AE, but I want to do the overlay in Premiere.
      running CC version 15.3 on Mac
        • 1. Re: Transparency different between AE and Premiere
          No clue without details. I suspect color management. Has this ever worked for you?
          • 2. Re: Transparency different between AE and Premiere
            darrenl60948965 Level 1
            What sort of details would be helpful? I can provide screenshots if that's helpful.
            Usually I export animation codec quicktime mov's set to lossless with alpha and I have not had this problem before.
            • 3. Re: Transparency different between AE and Premiere
              If you have not had problems before then what is different about this project? If it is just a single layer that is giving you problems selecting the layer and pressing the u key twice will reveal all modified properties so you can check the settings.
              Helpful details include AE version and OS version down to the last decimal point, checking to see if your software is up to date, workflow details including details of any specific effects that may be used, the kinds of footage you are working with or the types of files you are importing, what kind of color management you are using, and how you are judging the final product. I recently helped someone that was judging their renders using a media player that threw in a huge color shift that was not really there.
              Color management either needs to be off for everything of completely understood and properly utilized. If everything else is normal and you are seeing color shifts in the production workflow then color management is probably fouled up somewhere. If suspect color management problems the easiest thing to do to verify the problem is to render a frame from AE and render a frame from, in this case Premiere Pro, then take both frames into Photoshop and set the blend mode of the top copy to Difference. If the image does not turn completely black then you have a color management problem. If the image does turn completely black then you don't have a problem with the video, you have a problem with the software you are using to play back the film.
              • 4. Re: Transparency different between AE and Premiere
                I am not intentionally doing any Color Management, but in trying to figure out if it was on and how to turn it off I unchecked the 'Composite in Linear Color' box in the sequence settings, and that has solved my problem. Will that have any unintended consequences elsewhere in my project?
                • 5. Re: Transparency different between AE and Premiere
                  Unintended consequences depends entirely on your workflow. I strongly suggest that you type color management in the search help field at the top right corner of AE and spend some time with the Community Resources. If you have specific questions we need to know workflow details. There are just too many options to guess what may or may not happen to the color in your project.
