10 Replies Latest reply on Jan 29, 2018 11:32 PM by Geoffrey.F35
    After Effects 2017 - Black Screen on Playback
    jessicac14397771 Level 1
      Hello - I'm new to After Effects, but have been using it without problems for the past few weeks. Yesterday I went into Preferences and Emptied the Disk Cache and Cleaned the Database and Cache in order to improve performance. After doing that, playback of video or comp became veiled in black, with no audio. If I scrubbed with the playhead, I could see the video but that was the only way I could see anything. - I uninstalled and reinstalled AE 2017 but that didn't fix the problem. I uninstalled AE 2017 again and installed 2015. So far, 2015 is working normally. - Prior to installing 2015, I also upgraded to OSX Sierra so I could update my graphics card driver. That didn't fix the problem with AE 2017, but everything is up-to-date.
      I'm using both .mp4 files and .mov files. The same files that were working and visible before adjusting the Preferences settings would only playback under a black screen after adjusting the settings.
      I would like to be able to use the most current version of AE. Any suggestions as to how I can fix the playback issue with 2017? - I've looked on these forums and elsewhere and found a few other people describing a similar problem with a 'black screen.' The suggested solution often seems to be to empty the cache and clean the database. So, in my case, it seems the solution to some people's problems has been the cause of my problem. ???
      If it helps, here is my system info:
        Model Name: iMac
        Model Identifier: iMac14,2
        Processor Name: Intel Core i5
        Processor Speed: 3.2 GHz
        Number of Processors: 1
        Total Number of Cores: 4
        L2 Cache (per Core): 256 KB
        L3 Cache: 6 MB
        Memory: 16 GB
      NVIDIA GeForce GT 755M:
        Chipset Model: NVIDIA GeForce GT 755M
        Type: GPU
        Bus: PCIe
        PCIe Lane Width: x16
        VRAM (Total): 1024 MB
        Vendor: NVIDIA (0x10de)
        Device ID: 0x0fea
        Revision ID: 0x00a2
        ROM Revision: 3782
        Metal: Supported
        Display Type: LCD
        Resolution: 2560 x 1440
        Pixel Depth: 32-Bit Color (ARGB8888)
        Main Display: Yes
        Mirror: Off
        Online: Yes
        Automatically Adjust Brightness: Yes
        Built-In: Yes
