0 Replies Latest reply on Feb 7, 2017 3:09 AM by chrisp89193264
    Creating prov file error 14
    chrisp89193264
      Trying for ages to create the prov file for Premiere Elements 12, keep getting error code 14, tried at work, at home of different computers same issue.
      Command:
      C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\Enterprise\utilities\APTEE\CS6\adobe_prtk.exe --tool=VolumeSerialize --generate --serial=(myserial) --leid=V7{}PremiereElements-EMT[12]-Win-GM --regsuppress=ss --EulaSuppress
      Here is the log file. what am i doing wrong?
      2017-02-07 21:18:22 [3340]  Adobe PRTK: *** Adobe PRTK tool START ***
      2017-02-07 21:18:22 [3340]  Adobe PRTK: Adobe PRTK tool VolumeSerialize invoked
      2017-02-07 21:18:22 [3340]  Adobe PRTK: .
      2017-02-07 21:18:22 [3340]  Adobe PRTK: creating  .\prov.xml
      2017-02-07 21:18:22 [3340]  OOBELib: __OOBELIB_LOG_FILE__
      2017-02-07 21:18:22 [3340]  OOBELib: *************OOBELib Session Starts*************
      2017-02-07 21:18:22 [3340]  OOBELib: Version 6.2.0.43,6.2
      2017-02-07 21:18:22 [3340]  PCDService: PCD Service in non-threaded mode
      2017-02-07 21:18:22 [3340]  OPMWrapper: Failed in getting value for key in OPMGetValueForKey
      2017-02-07 21:18:22 [3340]  OOBELib: Failed to get Proxy username in OPM DB
      2017-02-07 21:18:22 [3340]  AXFBLicensing: Failed to load axlib.dll, trying again
      2017-02-07 21:18:22 [3340]  AXFBLicensing: Failed to load axlib.dll, trying again with axlib in ACF
      2017-02-07 21:18:22 [3340]  AXFBLicensing: All function pointers successfully retrieved
      2017-02-07 21:18:22 [3340]  OOBELib: Received Params for Online Validation : Driver : V7{}PremiereElements-EMT[12]-Win-GM, Caller : 3
      2017-02-07 21:18:22 [3340]  OOBELib: received LEID : V7{}PremiereElements-EMT[12]-Win-GM
      2017-02-07 21:18:22 [3340]  OOBELib: Supported Locales : ALL
      2017-02-07 21:18:22 [3340]  OOBELib: OOBELib ValidateSerialOnline
      2017-02-07 21:18:22 [3340]  OOBELib: Validate using Driver LEID : V7{}PremiereElements-EMT[12]-Win-GM, App LEID : <blank>, SN : 971400085900480326924654
      2017-02-07 21:18:22 [3340]  OOBELib: Failed to get system default proxy in setProxyCredentialsForIALSession
      2017-02-07 21:18:22 [3340]  OOBELib: Failed to set proxy credentials for IAL session while validating serial number
      2017-02-07 21:18:22 [3340]  OOBELib: HTTPCommunicationAgent::processMessage is https://lm.licenses.adobe.com/aes/aes/v1/serialInfo (extURL=)
      2017-02-07 21:18:24 [3340]  OOBELib: HTTP Request Status code 200.
      2017-02-07 21:18:24 [3340]  OOBELib: HTTPCommunicationAgent- Return Code:[0] response size-[232] time taken-[1509.72]ms.
      2017-02-07 21:18:24 [3340]  OOBELib: Got error from server-[9].
      2017-02-07 21:18:24 [3340]  OOBELib: ErrDesc from server: Some unknown error has occurred. : No associated Driver LEID is present in the database..
      2017-02-07 21:18:24 [3340]  OOBELib: Validate Serial status-[521] took-[1511.46]ms.
      2017-02-07 21:18:24 [3340]  OOBELib: OOBELib IAL VSN unknown error occured
      2017-02-07 21:18:24 [3340]  OOBELib: OOBELib IAL ValidateSerial call has failed : 521
      2017-02-07 21:18:24 [3340]  OOBELib: Using Driver/ALL combination for offline/invalid SNs scenario
      2017-02-07 21:18:24 [3340]  OOBELib: SN validated for AAMEE mode
      2017-02-07 21:18:24 [3340]  OOBELib: OOBELib stat = 257
      2017-02-07 21:18:24 [3340]  Adobe PRTK: Failed to validate the serial number
      2017-02-07 21:18:24 [3340]  Adobe PRTK: Return code 14
      2017-02-07 21:18:24 [3340]  Adobe PRTK: *** Adobe PRTK tool END ***
      Thanks Dylan
