0 Replies Latest reply on Dec 24, 2008 12:32 PM by xumichael
    a .NET WCF service with multiple contracts through Flex Builder 3’s Import Web Service (WSDL) Wizard
    xumichael
      Hi all,
      I ran into a problem when importing a .NET WCF service with multiple contracts through Flex Builder 3’s Import Web Service (WSDL) Wizard.
      Environment:
      .NET 3.5 Framework, Visual Studio 2008, Flex Builder 3, Windows XP SP2
      To make it simple, my scenario is:
      I defined 2 interfaces (really are contracts) “IFoo1” and “IFoo2”. My WCF service “FooService” implemented IFoo1 and IFoo2. I am hosting the “FooService” in a console app. From the .NET side, everything works. The service was running at http://localhost:8086/FooService.
      Now I imported the http://localhost:8086/FooService?wsdl in Flex Builder 3. The proxies generated were wrong.
      There were 2 bindings which is correct. If I choose Foo1HttpBinding, only proxies for IFoo1 were generated; if I select Foo2HttpBinding, then only proxies for IFoo2 were generated. OK, then I tried to put each set of proxies into its own package, still not work.
      Now I am concerned, is there anything wrong with my operation? Or Flex does not support WCF Service with multiple contracts, which means I need to put every operation inside one interface(contract)?
      Thank you very much for your help.
      Michael
      The abstraction of my codes are shown below:
      namespace MyNamespace
      [ServiceContract(Name = "IFoo1", Namespace = " http://services.mycompany.com/2009/12")
      public interface IFoo1
      [OperationContract]
      string Foo1();
      [ServiceContract(Name = "IFoo2", Namespace = " http://services.mycompany.com/2009/12")
      public interface IFoo2
      [OperationContract]
      string Foo2();
      [ServiceBehavior(Namespace = " http://services.mycompany.com/2009/12", InstanceContextMode = InstanceContextMode.PerCall)]
      public class FooService : IFoo1, IFoo2
      public string Foo1()
      return "Foo1";
      public string Foo2()
      return "Foo2";
      In the app.config:
      <services>
      <service name="MyNamespace.FooService">
      <host>
      <baseAddresses>
      <add baseAddress=" http://localhost:8086/FooService" />
      </baseAddresses>
      </host>
      <endpoint address="Foo1" binding="basicHttpBinding"
      name="Foo1HttpBinding" bindingNamespace=" http://services.mycompany.com/2009/12"
      contract="MyNamespace.IFoo1" />
      <endpoint address="Foo2" binding="basicHttpBinding"
      name="Foo2HttpBinding" bindingNamespace=" http://services.mycompany.com/2009/12"
      contract="MyNamespace.IFoo2" />
      </service>
