5 Replies Latest reply on Feb 7, 2017 12:14 PM by jasperwt
    Getting Error 'indexOf is not a function' - Acrobat X
    jasperwt
      Hello,
      I have a document level javascript that is looking for character strings to determine a result.
      Why would it throw this error?
      function webaddress() {
                var one = this.getField("CompanyName");
                var two = this.getField("WebAddress");
                var three = this.getField("dealerCSZ");
                var n = three.indexOf("MN,");
                var n1 = three.indexOf("IN,");
                var n2 = three.indexOf("OH,");
              // evaluate address for proper name
               if (n.value>=1)
                   one.value='TRUCK COUNTRY USED TRUCK CENTER';
                   two.value='www.truckcountry.com';
               else if (n1.value>0 || n2.value>0)
                   one.value='STOOPS FREIGHTLINER - QUALITY TRUCKS';
                   two.value='www.stoops.com';
               else
                   one.value='TRUCK COUNTRY';
      webaddress(); // call my function
        • 1. Re: Getting Error 'indexOf is not a function' - Acrobat X
          Bernd Alheit Adobe Community Professional & MVP
          You must use the value of the field. Example:
          var n = three.value.indexOf("MN,");
          • 2. Re: Getting Error 'indexOf is not a function' - Acrobat X
            Karl Heinz Kremer Adobe Community Professional
            Actually, you should use the valueAsString property instead of value - otherwise the code will throw an exception if the value is not already a string:
            var n = three.valueAsString.indexOf("MN,");
            • 3. Re: Getting Error 'indexOf is not a function' - Acrobat X
              jasperwt Level 1
              All - thanks for the quick reply.
              I added 'valueAsString' and am no longer getting an error.
              However, the variables n, n1, and n2 are all showing 'undefined' when I print them out.
              Is the indexOf method able to evaluate a comma?
              Here is the current script.
                        var n1 = three.valueAsString.indexOf("IN,");
                        var n2 = three.valueAsString.indexOf("OH,");
                       if (n.value>=1)
                           one.value='STOOPS FREIGHTLINER - QUALITY TRUCKS';               two.value='www.stoops.com';
                       else
              • 4. Re: Getting Error 'indexOf is not a function' - Acrobat X
                Use:
                if (n >= 1)
                Info: the variables n, n1, and n2 are local variables of the function.
                • 5. Re: Getting Error 'indexOf is not a function' - Acrobat X
                  jasperwt Level 1
                  You are absolutely correct!
                  Thanks for your help.
                  Works great.
