2 Replies Latest reply on Feb 7, 2017 8:34 PM by martinl90743871
    copy to clipboard
      Hi community,
      I'm working on a publish service and I'd like to use the goToPublishCollection menu (on the right click of a publish collection) to copy the remote URL into the clipboard.
      I still didn't find any solution to do that. Neither in the SDK or in the usual LUA documentation...
      Would you have any ideas? Is that possible with Lightroom_sdk?
      Thnk you!
        • 1. Re: copy to clipboard
          johnrellis Most Valuable Participant
          You can't do this directly with the SDK. But your plugin could use LrTasks.execute() to invoke a command-line utility that will set the contents of the clipboard.  A quick Google suggests "pbcopy" on Mac and "clip.exe" on Windows.
          • 2. Re: copy to clipboard
            martinl90743871 Level 1
            It is working!! Thank you Jogn!
            I don't think about LrTasks enough :-)
            Here is the solution in case somebody else want.
            local copyCmd = "echo '"..info.remoteUrl.."' | pbcopy"
            if prefs.os == "Windows" then
                  copyCmd = "Echo "..info.remoteUrl.." | clip"
