Every time I click and drag a transition between two clips (video or audio) a stupid pop up window titled "Transition Adjustments" pops up. How do I disable this time consuming, work flow halting, and creative juice drying new feature? I am currently editing with Elements 15 and am on the brink of changing over to something else because of this hand holding dumb add on.
[Moved from non-technical Forum Lounge to specific Program forum... Mod]
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
There is no way to turn this off as it is designed to allow you to customize your transitions.
However, as I show you in my book (on Amazon) there are two ways to avoid this feature:
1) Position your CTI playhead at the intersection of two clips, right-click and select Timeline/Apply Default Transition Along CTI; or
2) Select several clips on your timeline, right-click and select Timeline/Apply Default Transition. This will apply the default transition between every set of clips you have selected.
You can of course change the Default Transition by right-clicking on any transition in the Transitions panel and select the Set Default option.
