This content has been marked as final.
Show 1 reply
1. Re: Masking a Single Image in Multiple Separate Sections
clbeech Oct 15, 2008 7:51 PM (in response to andrewmcgibbon)you should be able to do this directly on the 'masking' layer - they are likely to be 'moving together' since you may be motion tweening 'both' on the same layer - this wont work, and you need to do one at a time - it may even be better to use 'shapes' rather than symbols in this case.
here is a 'sort of simliar' example:
http://forums.flashgods.org/sweepmask-t374.html
you 'could' use two layers and photos but it's not necessary.
