• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
How to combine multiple adobe Indesign documents ?
New Here ,
Feb 09, 2017 Feb 09, 2017
Dear Sir/Madam
PLEASE HELP.
How could we combine multiple adobe indesign documents into one pdf into adobe indesign cs6.
Please note : I don't want to use book and adobe acrobat. I want to use only adobe indesign cs6 or cc.
Views
10.9K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Mentor , Feb 09, 2017 Feb 09, 2017
@Willi Adelberger
See in the first post -
Topic starter want the spherical horse in a vacuum.
Don't want merging. Want some as you can do in the MS Explorer with .doc files - select files - right click - print.
I think that is a task for some script writer.
Votes
Translate
Translate
Mentor ,
you can place indd into indd.
http://indesignsecrets.com/zanelli-releases-multipageimporter-for-importing-both-pdf-and-indd-files....
Remember, never say you can't do something in InDesign, it's always just a question of finding the right workaround to get the job done. © David Blatner
Votes
Translate
Translate
Report
Report
New Here ,
I don't want to combine both .indd files into a .indd document. I wanted to generate a merged pdf of both .indd files.
Votes
Translate
Translate
Report
Report
LEGEND ,
Then you will need to Save/Print both InDesign documents as PDFs and then use some type of PDF creator/editor program to combine those 2 PDF documents into one PDF.
No other way around it. Of course you could take the suggestion from above to combine the 2 ID documents into one ID document then Save/Print that document as a PDF.
Votes
Translate
Translate
Report
Report
Advisor ,
Further to this point just use Adobe Acrobat DC and combine/arrange PDF's directly from here. Otherwise just drag and drop Indesign Pages from one save file to another.
Otherwise just drag and drop Indesign Pages from one save file to another since you only want to use Indesign.
Additional PDF pages could always be placed or exported into the INDD file.
Votes
Translate
Translate
Report
Report
Enthusiast ,
Hi joginderk,
Why don't you want to use the Book panel? It would be the best workaround.
Votes
Translate
Translate
Report
Report
Community Expert ,
Create an INDB InDesign Book File, and add all INDD into that. Export your PDF from the INDB Book Panel Menu.
Votes
Translate
Translate
Report
Report
Mentor ,
@Willi Adelberger
Votes
Translate
Translate
Report
Report
Community Expert ,
I am not sure why you want to avoid the solutions offered.
Unless you import your InDesign files into a single InDesign; InDesign does not really have a function to collate and compile several files into one other than the Book feature.
Maybe if you explained why you want to avoid the InDesign book feature we could help you better.
Votes
Translate
Translate
Report
Report
New Here ,
Thanks dear
I'll try some script
Votes
Translate
Translate
Report
Report
New Here ,
Jul 03, 2018 Jul 03, 2018
Hi - did you find a script that will merge multiple InDesign file into one InDesign file? My printer needs my files in this way. Doesn't want "book" file. Thanks!
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Why don’t you send a PDF?
Votes
Translate
Translate
Report
Report
Community Expert ,
Why do you not want the book functionality? IT IS PART OF INDESIGN! You don't need a different program. That is the easiest way.
It seems to me, that you don't know what the INDB functionality means in InDesign. Please learn it to use. That is the simplest solution.
Votes
Translate
Translate
Report
Report
Community Expert ,
Dear Sir/Madam
PLEASE HELP.
To sum up:
You can use the book feature and make a PDF of the two documents. (non-destructive)
You can use Acrobat or another PDF editor to merge the PDFs (non-destructive)
You can combine the documents in InDesign using the Pages panel menu and moving pages (this could possibly cause problems)
Votes
Translate
Translate
Report
Report
Community Expert ,
Combining PDFs later in Acrobat may cause much bigger files than exporting an INDB as embedded fonts could be doubled and other shared resources will be saved several times, at least for each of them once. So it is better to export from an INDB.
Votes
Translate
Translate
Report
Report
