3 Replies Latest reply on Feb 14, 2017 10:54 PM by Laubender
    Can I Convert a Paragraph Style to a Script Label?
    sidd32925467 Level 1
      Hi all.
      Is it possible to convert a Paragraph Style to a Script Label?
      I have multiple boxes and so deleting or converting the style to text isn't an option.
      I have the below but the Script Label reads "[object cell]'.
      //This is only part of the script
      //Place  canvas code
      var myText = myTable.rows[6].cells[3];
      var myParaStyle = myDocument.paragraphStyles.item("Lightbox Code");
      myText.texts.item(0).applyParagraphStyle(myParaStyle, true);
      myText.contents = "\r";
      //Script label
      var scriptLabel = myText.toString();
      myCell.pageItems[0].label = scriptLabel;
        • 1. Re: Can I Convert a Paragraph Style to a Script Label?
          milligramme Level 3
          `myText` is not proper variable name, this is Cell Object.
          I guess using `appliedParagraph.name` to Cell's Text solve your issue.
          thank you
          • 2. Re: Can I Convert a Paragraph Style to a Script Label?
            Hi MG.
            Sorry but can you explain further?
            I've tried the below code but get an error message -
            //Script label
            var scriptLabel = myTable.rows[6].cells[3].appliedParagraph.name;
            • 3. Re: Can I Convert a Paragraph Style to a Script Label?
              Hi sidd,
              look up the DOM documentation and Help files of the ESTK.
              Some valuable links in this thread here:
              Re: indesign scripting tutorial
              Object Cell has a texts property.
              And object Texts has appliedParagraphStyle property. Not appliedParagraph.
              And appliedParagraphStyle is indeed a PargaraphStyle, that has a name property.
              And if the value of name is what you are after you can do it like that:
              var scriptLabel = myTable.rows[0].cells[3].texts[0].appliedParagraphStyle.name;
              because the value of name is a String object.
              Labels can hold only Strings as value.
              What exactly is behind variable myCell ?
              And is a pageItem pasted in myCell?
              Or is myCell a graphic cell and pageItems[0] is the container of an image that sits in the cell?
              Note: You can also use the cell itself to label it.
              myCell.label = scriptLabel;
              And if you select the cell and the Script Label panel is open you will see the value of the label.
              Example from my German InDesign CC 2017:
              ( Skriptetikett => Script Label , [Kein Absatzformat] => [No Paragraph Style] )
              If you go through the cells using the arrow keys, the script label is changing, because I applied different paragraph styles and labeled all the cells:
