Hello everyone,
I am running into a problem where my indesign just completely freezes returning no error code when I run this script, the goal is that indesign will create a document with the same number of pages as the selected pdf. This is what I have so far:
Initialization();
function Initialization() {
//prompt user to select a file.
var selectedFile = File.openDialog("Choose a PDF File");
//Retrieve the page count of the selected file.
var pageCount = readPageCount(selectedFile);
createDoc(selectedFile, pageCount);
// This function is based on another script and believe the issue lies within this section here:
function readPageCount(selectedFile) {
// Read in first line of section
var theLine = selectedFile.readln();
// Locate the line containing the /Count entry
while(theLine.indexOf("/Count") == -1)
// Extract the page count
return parseInt(theLine.substring(theLine.indexOf("/Count") +6), 10);
function createDoc(selectedFile, pageCount) {
//Create a new document with the same number of pages as the selected document.
var BC10UP = app.documents.add();
with (BC10UP.documentPreferences) {
pageHeight = "11in";
pageWidth = "8.5in";
pageOrientation = PageOrientation.landscape;
pagesPerDocument = pageCount; }
any help or advice is much appreciated!!
Well I have already found a noob mistake, should be item(0) not item [0]. Setill learning :,)
1. selectedFile should be opened before calling readln()
2. looks like not every pdf contain the string "/Count" (at least some on my side)
do a "while loop" with selectedFile.eof condition and break a loop if the string "/Count" is found
something like:
selectedFile.open("r");
do {
theIndex = theLine.indexOf("/Count");
if (theIndex >=0) {
selectedFile.close();
return parseInt(theLine.substring(theIndex + 6), 10)
while (!selectedFile.eof)
return -1
if -1 returned desired string is not found
Jarek
