• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
JPEG quick tool - AA Pro DC
Community Beginner ,
Feb 09, 2017 Feb 09, 2017
So basically I take PDF's and make them into images so that I can place them in documents. And I do this quite a few times a day.
Looking to find a way to create a quick tool that will do that with one press in Adobe Acrobat Pro DC. Any help would be great, as I tried to make one... but couldn't find my way after navigating all the sub menus.
[Moved from non-technical Forum Lounge to an Acrobat forum... Mod]
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
TOPICS
Edit and convert PDFs
Views
378
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Feb 09, 2017 Feb 09, 2017
OK, in order to be able to do it you need to create a js file (for example, SaveAsJpeg.js) and place it under Acrobat's JavaScripts folder.
In the file place this code:
app.addMenuItem({cName: "SaveAsJPEG", cUser: "Save As JPEG", cParent: "File", nPos: 5,
    cExec: "myTrustedSaveAsAndConvert(this, this.path.replace(/pdf$/i, \"jpg\"), \"com.adobe.acrobat.jpeg\");",
     cEnable: "event.rc = (event.target != null);"
safeSaveAsAndConvert = app.trustPropagatorFunction(function(doc,vPath,vConv){
    a
Votes
Translate
Translate
Community Expert ,
It's possible to do it using a script. I'll post the code in a moment...
Votes
Translate
Translate
Report
Report
Community Expert ,
    app.beginPriv();
    doc.saveAs({cPath:vPath, cConvID: vConv});
    app.endPriv();
myTrustedSaveAsAndConvert = app.trustedFunction(function(doc,vPath,vConv){
    app.beginPriv();
    safeSaveAsAndConvert(doc,vPath,vConv);
    app.endPriv();
This will add a new menu item to the File menu of Acrobat, called "Save As JPEG", which will export all the pages in the currently open file as JPEG images in the same folder and using the same name (with a "_Page_X" suffix) as the original file. You can play around with the values of the nPos parameter if you want to move it up or down the menu items. You'll need to restart Acrobat after every change you make to it, though.
Votes
Translate
Translate
Report
Report
Thank you so much... that was super awesome. One more question, tried finding the code to add a shift + ctrl (key modifier) to do it quickly. Cant seem to find it and place it.
Votes
Translate
Translate
Report
Report
Community Expert ,
That's not possible, I'm afraid. Best you can is add a keyboard accelerator so you could access it using a specific key.
To do that change this part of the code:
To this:
cUser: "Save As &JPEG"
You'll then be able to execute it by pressing Alt+F, and then J.
Votes
Translate
Translate
Report
Report
LATEST
That's even better. Thank you again for the code and short cut! You are awesome!
Votes
Translate
Translate
Report
Report
