6 Replies Latest reply on Apr 10, 2017 1:58 PM by jbm007
    Adobe Photoshop CC 2017 has stopped working
    yayt55131604
      Hi all,
      i am getting this error when i open the application "Adobe Photoshop CC 2017 has stopped working"i have HP workstaion Z800 desktop and using Nvidea Quadra 4000 graphics card , also all drivers up to date and tried to roll back one by one and still same issue.
      i had rebuilded the OS but nothing change
      OS : Windows 10 / windows updated latest version.
      is there any way to fix this problem.
      Best Regards.
        • 1. Re: Adobe Photoshop CC 2017 has stopped working
          Post the detail in the crash report ues the reliability history viewer to find the photoshop stopped working ones.  I have Windows 10 preview 15031 Imstalled and a Nvidia Quadro 4000  every time I install a new Windows 10 Preview  Photoshop sill works but openCl is grayed out I need to reinstall the nvidia device driver for the Quadro 4000.  I have CS2, CS6, CC, CC 2014, CC 2015, CC 2015.5 and CC 2017 Installed.  CC2014 has the fewest bugs.
          • 2. Re: Adobe Photoshop CC 2017 has stopped working
            sumitg919874 Level 1
            Try to Reinstall your Software
            or You Can Simply Download from Adobe Site
            I am Sure you Will get Problem Solved
            Best Regards
            <Advertising removed by Moderator>
            • 3. Re: Adobe Photoshop CC 2017 has stopped working
              jbm007 Adobe Community Professional
              Mack is correct.
              You need to go to the Nvidia site and make sure you have the latest video driver from that site.
              Often windows updates will install or over write video drivers with a generic approved windows driver.
              If you continue to crash Photoshop go to the control panel/administrative tools/event viewer/windows logs/application and find the latest crash report.
              on the right side select copy  "copy as text" and post the report here.
              • 4. Re: Adobe Photoshop CC 2017 has stopped working
                davesonoma1 Level 1
                I ran the event viewer and in my case found the problem was related to AdAware's software (specifically, LavasoftTcpService64.dll). I uninstalled the software and restarted and Photoshop works again. I have had enough video card troubleshooting for a lifetime, so I'm glad I was able to avoid that particular problem this time.
                2 people found this helpful
                • 5. Re: Adobe Photoshop CC 2017 has stopped working
                  DanaHenke
                  Log Name:      Application
                  Source:        Application Error
                  Date:          4/10/2017 1:24:47 PM
                  Event ID:      1000
                  Task Category: (100)
                  Level:         Error
                  Keywords:      Classic
                  User:          N/A
                  Computer:      VMDW7309087.CMUTUAL.com
                  Description:
                  Faulting application name: Photoshop.exe, version: 18.0.1.29, time stamp: 0x583e911d
                  Faulting module name: ntdll.dll, version: 6.1.7601.23677, time stamp: 0x589c99e1
                  Exception code: 0xc0000374
                  Fault offset: 0x00000000000bf3e2
                  Faulting process id: 0xd34
                  Faulting application start time: 0x01d2b227b76c3453
                  Faulting application path: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Photoshop.exe
                  Faulting module path: C:\WINDOWS\SYSTEM32\ntdll.dll
                  Report Id: f9573e52-1e1a-11e7-9da6-005056a310da
                  Event Xml:
                  <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
                    <System>
                      <Provider Name="Application Error" />
                      <EventID Qualifiers="0">1000</EventID>
                      <Level>2</Level>
                      <Task>100</Task>
                      <Keywords>0x80000000000000</Keywords>
                      <TimeCreated SystemTime="2017-04-10T18:24:47.000000000Z" />
                      <EventRecordID>24113</EventRecordID>
                      <Channel>Application</Channel>
                      <Computer>VMDW7309087.CMUTUAL.com</Computer>
                      <Security />
                    </System>
                    <EventData>
                      <Data>Photoshop.exe</Data>
                      <Data>18.0.1.29</Data>
                      <Data>583e911d</Data>
                      <Data>ntdll.dll</Data>
                      <Data>6.1.7601.23677</Data>
                      <Data>589c99e1</Data>
                      <Data>c0000374</Data>
                      <Data>00000000000bf3e2</Data>
                      <Data>d34</Data>
                      <Data>01d2b227b76c3453</Data>
                      <Data>C:\Program Files\Adobe\Adobe Photoshop CC 2017\Photoshop.exe</Data>
                      <Data>C:\WINDOWS\SYSTEM32\ntdll.dll</Data>
                      <Data>f9573e52-1e1a-11e7-9da6-005056a310da</Data>
                    </EventData>
                  </Event>
