23 Replies Latest reply on Dec 10, 2010 1:43 AM by marioterzo
    Read a CSV file into Flex
    Kieran Briggs
      Hi all,
      I'm new to flex and have been asked to provide a small widget that will display the contents of a csv in a list. Can I use the HTTPService to open a csv file and then create an actionscript 3 function to parse it? If so can anyone point me to a tutorial on how to parse a csv file please.
      Thanks in advance
        • 1. Re: Read a CSV file into Flex
          ntsiii Level 3
          I've not done this in AS, but it shouldn't be too difficult.
          You will just need to use split() to first put the lines in an array then again to put the fields in an array for each line.
          Split the fields on comma, obviously. I'd have to experiment some to see how to split the lines on CR.
          You might google this, someone has probably already done it.
          Tracy
          • 2. Re: Read a CSV file into Flex
            parrygill Level 1
            Hello Sir,
              I am new to flex and want to read a csv file and using below code but does not seems to be working. Can you please help?
              i use below code but did not work
            var file:File = evt.currentTarget as File;
                     file = file.resolvePath(file.nativePath);
                     var fileStream:FileStream = new FileStream();
                     fileStream.open(file, FileMode.READ);
                     var fileData:String =  fileStream.readUTFBytes(fileStream.bytesAvailable);
                     var endings:Array = [File.lineEnding, "\n", "\r"];
            but for some reason it return "ÐÏ ࡱá" funny value. Any idea why don't i get the correct data from file.
            belwo is the csv file i am trying to open.
            Title
            Given_Name
            Surname
            Gong
            Salutation
            Position
            Organisation
            Address_Line_1
            Address_Line_2
            Address_Line_3
            Suburb
            State
            Postcode
            Country
            Home_Phone
            Fax
            Other_Phone
            User_Field_1
            User_Field_2
            User_Field_3
            User_Field_4
            Mobile_Phone
            Second_Address
            Second_Address_Line_1
            Second_Address_Line_2
            Second_Address_Line_3
            Second_Suburb
            Second_State
            Second_Country
            Second_Postcode
            Langcode
            Website
            Mr.
            Jeff
            Alexander
            Retention Marketing
            Monday, April 13th, 2009
            Mr.
            Anthony
            Demaso
            Retention Marketing
            Sally
            Swinamer
            Yield
            Chris
            Torbay
            Yield
            Annette
            Warring
            Genesis Vizeum
            Mr.
            Mark
            Khoury
            Genesis Vizeum
            Mr.
            Andy
            Thorndyke
            Thorsons
            Shannon
            Rutherford
            Central Reproductions
            Mr.
            Rob
            Greenwood
            Lisa
            Marchese
            Des Rosiers
            Mr.
            Michael
            Whitcombe
            McMillan LLP
            Gill
            • 3. Re: Read a CSV file into Flex
              *Prashant Shelke* Level 4
              Please find attachment.
              • 4. Re: Read a CSV file into Flex
                parrygill Level 1
                Thanks for your help.I have browse button to open the file and use will select the file location. That's why i am using current approach. can you please send me sample code to read the attached xls file please.
                • 5. Re: Read a CSV file into Flex
                  Chandra2034 Level 1
                  I am using following code to read xlsx file in Flex AIR 4 code. It not reading anything I am getting "PK   "  as output.
                  Please help me to read correctrly xlsx file in Flex.
                  private function btnCSV_click():void
                  var strFilePath :String = File.applicationDirectory.nativePath + "\\Test.xlsx";
                  var loader:URLLoader = new URLLoader();
                  configureListeners(loader);
                  var request:URLRequest = new URLRequest(strFilePath);
                  request.contentType =
                  "text/csv";
                  try {
                  loader.load(request);
                  catch (error:Error) {
                  trace ("Unable to load requested document.");
                  private function configureListeners(dispatcher:IEventDispatcher):void
                  dispatcher.addEventListener(Event.COMPLETE, completeHandlerCSV);
                  private function completeHandlerCSV(event:Event) :void
                  trace ( event.target.data );
                  • 6. Re: Read a CSV file into Flex
                    Flex harUI Adobe Employee
                    An xlsx file is not a CSV file.
                    • 7. Re: Read a XLSX file into Flex
                      Chandra2034 Level 1
                      Yeah, I can read CSV file but not xlsx file. How to read xlsx file ?
                      • 8. Re: Read a CSV file into Flex
                        You will need to find doc on the format and use ByteArray
                        • 9. Re: Read a xlsx file into Flex
                          Chandra2034 Level 1
                          Thanks Flex harUI. Please refer me any example which shows how to convert ByteArray to actual data. I read xlsx file using ByteArray format but could not decode result to actual data.
                          Question : Is Flex AIR4 support reading xlsx file ?
                          • 10. Re: Read a CSV file into Flex
                            There is no built-in support for xslx file.  I don't the format so I can't
                            help you with the decoding.  I'm pretty sure it is compressed so you will
                            probably need to involve ByteArray inflate() or uncompress() at some point.
                            • 11. Re: Read a CSV file into Flex
                              marioterzo
                              I am trying to use the code enclosed, :
                                package
                                      import flash.display.Sprite;
                                      import flash.net.URLLoader;
                                      import flash.net.URLRequest;
                                      import flash.events.Event;
                                      import flash.events.IEventDispatcher;
                                    public class LoadCSV extends Sprite
                                         public function LoadCSV():void {
                                             var request:URLRequest = new URLRequest("http://www.???.com/path/to/csv/file.csv");
                                             try {
                                             } catch (error:Error) {
                                         private function configureListeners(dispatcher:IEventDispatcher):void {
                                             dispatcher.addEventListener(Event.COMPLETE, completeHandler);
                                         private function completeHandler(event:Event)
                              If I want to read a csv file on my hard disk how to write the:  new URLRequest("http://www.???.com/path/to/csv/file.csv");  ??
                              new URLRequest("myfile.txt")  gives  me a flux error...
                              thanks
                              • 12. Re: Read a CSV file into Flex
                                Chandra2034 Level 1
                                create a file object and pass and pass it's nativepath in UrLRequest.
                                • 13. Re: Read a CSV file into Flex
                                  marioterzo Level 1
                                  thanks !!! now I try...
                                  but in my project I cannot import flash.filesystem.File;
                                  do you know what libraries I must add, and where to find it ??
                                  thanks... (adobe libraries are not like java ...)
                                  • 15. Re: Read a CSV file into Flex
                                    marioterzo Level 1
                                    I am searching the Api 'flash.filesystem', where I can find it ? I must pay ?
                                    thanks
                                    • 16. Re: Read a CSV file into Flex
                                      Chandra2034 Level 1
                                      I did not get your question...
                                      • 17. Re: Read a CSV file into Flex
                                        marioterzo Level 1
                                        I need to use the class File, so I must write 'impot flash.filesystem.File' , but my system does not see this package...
                                        • 18. Re: Read a CSV file into Flex
                                          Chandra2034 Level 1
                                          Yeah... seems like  I was using Flash Builder 4.
                                          • 19. Re: Read a CSV file into Flex
                                            marioterzo Level 1
                                            yes, I am using just flash bulder 4..
                                            this is not a public library ?????????
                                            • 20. Re: Read a CSV file into Flex
                                              marioterzo Level 1
                                              I have found, at last, using URLLOADER. And I have understood that the library flash.filesystem is only for AIR ....
                                              • 21. Re: Read a CSV file into Flex
                                                marioterzo Level 1
                                                another question : if I want to read from my desktop what I must write instead of :
                                                var request:URLRequest = new URLRequest("myfile.txt");
                                                thanks....
                                                • 22. Re: Read a CSV file into Flex
                                                  marioterzo Level 1
                                                  any suggestions to read from the desktop ?
                                                  thanks...
                                                  • 23. Re: Read a CSV file into Flex
                                                    marioterzo Level 1
                                                    I have found the solutions to my problems, read a file .csv (using Flex and Flash Builder 4).
                                                    To read and process a text file I have used 'flash.net.FileReference';
                                                    "The FileReference class provides a means to upload and download files between a user's computer and a server.
                                                    An operating-system dialog box prompts the user to select a file to upload or a location for download.
                                                    Each FileReference object refers to a single file on the user's disk and has properties that contain information
                                                    about the file's size, type, name, creation date, modification date, and creator type (Macintosh only)."
                                                    "The FileReference Object first open up a file browsing dialog window on the user's machine with the browse() method and
                                                    prompt the user to select a local file to upload. Once the user select the file to upload, the FileReference Object
                                                    will upload the selected file to a web server that is specified in the upload() method. Once the file is uploaded
                                                    by the FileReference Object, it will not be uploaded to the web server immediately, instead it will be uploaded
                                                    to the browser's temp directory."
                                                    Then, you need a server side script, that comes in and it will check the existence of the upload file.
                                                    If the file exists then the server side script will move the file from the browser's temp directory to
                                                    the specify directory of the server.
                                                    For this I have used Apache commons 'fileUpload', writing a java jsp.
                                                    The file csv must stay in the same directory as your published files.
