• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Experiencing delayed start of Lightroom 2015.8 on new SSD, Develop Module issue? anyone else?
Explorer ,
Feb 11, 2017 Feb 11, 2017
Morning, did a recent fresh install of Windows 10 64bit, on my EVO SSD, Lightroom catalog and photos are on the SSD drive as well. I have 16GB RAM XPS 8700 i7. AMD Radeon HD 7500 Graphics card Driver 15.201.1151.1008. Prior to reinstall of windows I vvaguelyremember Lr booting up quicker or no delay. Now...
After clicking Lr it takes 10 Seconds before the Lr splash screen pops up.
Then if it goes straight to Develop Module another 50 seconds before I can actually use Lr, I get the current photo and "LOADING" until for about 50 seconds and if I try to click it hangs until it finishes.  After this wait period, Lr runs fine, but I don't remember this prior to upgrading to my SSD and would think it should run ALOT faster. I know the DEVELOP rely's on CPU speed vs. Drive speed, but again, don't remember this issue before.
I've tried the (Performance) Graphics checked and unchecked and same. I've tried creating a new catalog importing about 10 photos and creating 1:1. But same issues. Ran that test multiple times with same results.
NOW.... If I switch to Library Module, exit and retry, it still takes 10 seconds before anything happens / I get the Lr splash screen, BUT then in about 2-3 seconds I can use Lr and browse my library AND once I go into the DEVELOP module, it freezes again for 15+ seconds....
Any thoughts?
Views
809
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer , Feb 11, 2017 Feb 11, 2017
I FIGURED IT OUT:
ACRONIS TRUE IMAGE - Active Protection was ON, after going through everything 1 by 1 that was it....
Thank you all for the help and time
Votes
Translate
Translate
LEGEND ,
Apparently there is a potential speed issue with Samsung EVO drives concerning "old" files that have been on the drive for a while: Samsung addresses slow 840 EVO SSD performance with another patch - TechSpot
Not sure if this is your issue, but you can run this test program to check:
SSD Read Speed Tester 2.04 Download - TechSpot
Votes
Translate
Translate
Report
Report
Explorer ,
What type of "old" files?  I did a clean install of everything.  I have the EVO 850 SSD that was just bought 2 weeks ago, latest firmware.  And the delay appears only with Lr.
Votes
Translate
Translate
Report
Report
LEGEND ,
I understand that you have no "old" files on the SSD, but that doesn't rule out this as the cause.
I suggest downloading Samung's Magician tool as outlined at the first link. Check that the latest firmware version is installed on the SSD and if not install the latest update. Once that's done you can run the SSD Read Speed test at the 2nd link. Shouldn't take very long to run both and rule that out. If the latest firmware is loaded and the drive passes the Read Speed test we can look at other causes. Does that sound prudent?
Votes
Translate
Translate
Report
Report
Explorer ,
Thanks, yes I ran magician have the latest firmware  and no issues with read and write.    Very frustrating.
Votes
Translate
Translate
Report
Report
Explorer ,
I have a similar system to you with the exception of (GTX 1080 and intel i7 6800K):
2 x EVO 850 drives, one holds the system and Adobe programs and the other is for programs not used often and my lightroom catalog, cache and IMPORT folder (photos for sorting which are keyworded, rated/edited and then moved to the data drive) a third 2TB data drive contains all my photos.
This works very fast and I am working with very large NEF files from a D800, my library has 30k images.
Votes
Translate
Translate
Report
Report
Community Expert ,
Might be time to try resetting your Lightroom preferences.
Votes
Translate
Translate
Report
Report
Explorer ,
I also tried that, resetting entire preferences, rebooting. Also reinstalled Lightroom after full uninstall.
Assuming it doesnt have anything to do w graphics card.  Photoshop works fine.
Votes
Translate
Translate
Report
Report
Community Expert ,
Hmm, in that case, you might need to dig deeper. I don't know where on Windows system log files are stored but you might need to monitor those to see if there is any hint about why the program behaves so abnormally. This is definitely very strange. The fact that it is triggered by going into Develop might mean two things. One that your graphics card is indeed an issue but that should be better when you uncheck GPU acceleration and second that your camera raw cache is polluted. Did you try to reset and purge the camera raw cache? It's in "Preferences->File handling" also make sure it is in a good location on your SSD and that it doesn't have a strange path defined there that doesn't exist anymore.
Votes
Translate
Translate
Report
Report
Explorer ,
@Jao vdL - I purged the Cache, It's stored in default location users/xx/appdata/local/adobe/cameraraw/cache.  I also have it set a 25GB.
trshaner​ I use Spyder Pro and have both monitor's calibrated.  My one monitor is an Acer S275HL and using the Generic PnP Monitor Driver the other is an older Samsung SyncMaster 24".
Votes
Translate
Translate
Report
Report
Explorer ,
I just tried installing the Acer S275HL monitor to remove the Generic PnP and still same issues....
Votes
Translate
Translate
Report
Report
LEGEND ,
I suggest assigning the sRGB profile to both monitors as outlined at the link I provided to eliminate this as the possible cause. Most calibration software creates ICC Vesion 4 LUT type profiles with their default Preferences settings. This has caused some users to experience LR performance issues.
Votes
Translate
Translate
Report
Report
Explorer ,
trshaner​ Ok, i'll give it a try, but I was calibrating my monitor previous to the fresh install.
Also, is there a specific setting? I would assume the calibration software shouldn't cause that issue as the majority of people that buy the calibration hardware/software are using it for Lr and Ps...
Votes
Translate
Translate
Report
Report
Explorer ,
Ok, Just set both profiles as instructed in the link.  Rebooted CPU confirmed profiles are default, and still the same... Man this is frustrating... And thank you for troubleshooting this with me...
Votes
Translate
Translate
Report
Report
LEGEND ,
OK, so we can eliminate the display profiles as the cause.
The fact that the issue gets triggered when you go into the Develop module may indicate an issue with the CC activation process. Make sure you are connected to the Internet, close all Adobe apps, and then 'Sign Out' and 'Sign In' to your CC account as outlined here: Sign in and sign out to activate or deactivate Creative Cloud apps
Votes
Translate
Translate
Report
Report
Community Expert ,
Hmm that is then really strange. This has to be a specific hardware issue or perhaps some driver acting up. Do you have something like a Wacom tablet or other input device. Any external hard disks?
Votes
Translate
Translate
Report
Report
Explorer ,
I did try the sign in/out before as I read that elsewhere on the www as a possible solution, I tried it again but no luck.
No Wacom tablet, I disconnected all of my external drives, shut off my raid, so it was just my SSD internal and SATA internal...   So is the 10 second delay to the Lr splash screen normal? and just issue may be with Develop module?
I tried updating my graphics driver and didn't work either.
Votes
Translate
Translate
Report
Report
Community Expert ,
10 seconds is long especially on such a speedy machine. My laptop with an i7 processor takes 3 seconds to see the splash screen. A few more seconds and it is ready to use. Not super fast but certainly not the eons you are describing.
Votes
Translate
Translate
Report
Report
Explorer ,
Yea, My laptop is almost isn't too.  Not sure what the issue could be...  Frustrating
Votes
Translate
Translate
Report
Report
Explorer ,
So I reran Samsung Magician Results:
Sequential
Read 3,363
Write 2,568
Random IOPS
Read 69,575
Write 52.926
Votes
Translate
Translate
Report
Report
Explorer ,
I FIGURED IT OUT:
Votes
Translate
Translate
Report
Report
LEGEND ,
Feb 12, 2017 Feb 12, 2017
LATEST
Glad you found it and thank for reporting back! I suggest reporting this issue to Acronis Customer Service and see if they have a solution: Customer Service & Support - Acronis
Votes
Translate
Translate
Report
Report
LEGEND ,
One other possibility is the monitor profile. Windows 10 has been known to install OEM display profiles that are incompatible with LR. The symptoms are slow performance and/or color rendering issues. Try assigning the sRGB profile if you are using a standard gamut monitor or Adobe RGB profile if using a wide gamut monitor as outlined here: https://www.lightroomqueen.com/articles-page/how-do-i-change-my-monitor-profile-to-check-whether-its...
Votes
Translate
Translate
Report
Report
