1. Re: Photoshop Preference Settings doesn't work. I need someone to help me
D Fosse Feb 11, 2017 12:28 PM (in response to anahitv40880043)Set UI scaling to 200%. That's the only relevant preferences setting here. The default Auto setting should pick up your screen resolution, but sometimes it doesn't.
2. Re: Photoshop Preference Settings doesn't work. I need someone to help me
anahitv40880043 Feb 11, 2017 3:06 PM (in response to D Fosse)Thanks for your attention D Fosse.
It doesn't change anything when I set UI Scaling 200%, even the Colors Theme are not working, just not changing.
3. Re: Photoshop Preference Settings doesn't work. I need someone to help me
jbm007 Feb 11, 2017 6:50 PM (in response to anahitv40880043)What laptop do you have.
Whats its screen resolution?
What video card is installed.
4. Re: Photoshop Preference Settings doesn't work. I need someone to help me
anahitv40880043 Feb 12, 2017 2:05 AM (in response to jbm007)Thanks for your attention jbm007.
Here are my notebook properties
Aspire R5-571T
Windows 10
Processor - Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz 2.40GHz
Installed - RAM 8,00GB
System type - 64-bit operating system, x4-based processor
Screen size - 39.6 cm (15.6")
Screen resolution - 1920 x 1080
Graphics decice - Intel(R) HD Graphics 520
Multi-touch Screen
5. Re: Photoshop Preference Settings doesn't work. I need someone to help me
davescm Feb 12, 2017 3:07 AM (in response to anahitv40880043)Hi
It is strange that Preferences changes are having no impact. Just a thought - after each change are you clicking on "OK" then closing down and re-starting Photoshop?
Dave
6. Re: Photoshop Preference Settings doesn't work. I need someone to help me
jbm007 Feb 12, 2017 5:52 AM (in response to anahitv40880043)Have you updated all your system drivers since you got your laptop?
Nice kit, wondering if it could be system related:
You could also select the PS icon and under compatibility select "disable display scaling on high DPI settings" and see if that helps.
8. Re: Photoshop Preference Settings doesn't work
edgrimley Feb 12, 2017 9:43 AM (in response to anahitv40880043)"...then closing down and re-starting Photoshop?"
9. Re: Photoshop Preference Settings doesn't work
davescm Feb 12, 2017 11:09 AM (in response to anahitv40880043)Hi
Sorry for asking the obvious - but sometimes users do not realise that it is necessary to both click OK and restart Photoshop.
The two screenshots you provided show that the Photoshop preferences are changing your UI size. The only two settings are 100% and 200% (auto just picks one of those two automatically). There is no in -between setting (although many have requested it).
Dave
10. Re: Photoshop Preference Settings doesn't work
anahitv40880043 Feb 12, 2017 12:32 PM (in response to davescm)Hi davescm
Yes after clicking "OK" I am restart Photoshop.
When I set Interface Auto or 100% they are same small size, and it's really hard to work, I couldn't see anything. You can see in image that I attached, 200% interface is frightfully for designer, there isn't much space to work.
I couldn't understand why in Illustrator Interface is good but in Photoshop its different.
What else I could do to solve this problem
11. Re: Photoshop Preference Settings doesn't work
davescm Feb 12, 2017 12:46 PM (in response to anahitv40880043)Hi
Illustrator preferences show that 100% , 150% and 200% scaling is supported. Unfortunately in Photoshop only 100% and 200% are currently supported.
See the link below in which 150% scaling has been requested and to which Adobe responded that they are working on the issue
Photoshop cc 2017: UI scaling needs 150% | Photoshop Family Customer Community
Dave
12. Re: Photoshop Preference Settings doesn't work
anahitv40880043 Feb 12, 2017 1:09 PM (in response to davescm)
