2 Replies Latest reply on Jun 7, 2017 3:42 PM by haytame76384215
    adobe photoshop CC 2017 has stop working
    mycakesmypassion
      hi all
      from few weeks I see info on my screen (Adobe Photoshop CC 2017 has stop working and this is ) when I try run Photoshop
      this was happen after some update because before was ok
      I working on Toshiba laptop windows 8.1
      is any chance to fix this??
      thanks for answers
      best regards
      Sebastian Z
        • 1. Re: adobe photoshop CC 2017 has stop working
          gener7 Adobe Community Professional & MVP
          Usually in Windows, you look for the "Faulting Module" that causes the crash.
          As of late, "Web Companion" has been the cause. If you go into the Control Panel > Programs and uninstall it. Restart your PC.
          If it isn't the problem,
          I would recommend you to check event viewer logs, look for event errors after Photoshop crashes.  Follow these steps to access Event Viewer.
          1. Go to the Start Screen.
          2. Type in Event Viewer.
          3. This will bring up the Event Viewer box. Click to open the Event Viewer.
          4. In the left pane, expand Windows Logs.
          5. Click on Application and System log.  Highlight the first event in the log and use your arrow keys to scroll down. Most of your event will be in formation. You may see Yellow Warnings or Red Errors. If you see a red error, you can double click on it to bring it up and copy/paste the contents to this forum.
          • 2. Re: adobe photoshop CC 2017 has stop working
            haytame76384215
            Log Name:      Application
            Source:        Application Error
            Date:          6/8/2017 12:40:51 AM
            Event ID:      1000
            Task Category: (100)
            Level:         Error
            Keywords:      Classic
            User:          N/A
            Computer:      hp-PC
            Description:
            Faulting application name: Photoshop.exe, version: 18.1.1.252, time stamp: 0x58737f6a
            Faulting module name: Photoshop.exe, version: 18.1.1.252, time stamp: 0x58737f6a
            Exception code: 0xc0000005
            Fault offset: 0x000000000ae17b88
            Faulting process id: 0x174c
            Faulting application start time: 0x01d2dfdef8ecd4d5
            Faulting application path: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Photoshop.exe
            Faulting module path: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Photoshop.exe
            Report Id: 5b865678-4bd2-11e7-a54e-b4b676fa55e5
            Event Xml:
            <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
              <System>
                <Provider Name="Application Error" />
                <EventID Qualifiers="0">1000</EventID>
                <Level>2</Level>
                <Task>100</Task>
                <Keywords>0x80000000000000</Keywords>
                <TimeCreated SystemTime="2017-06-07T22:40:51.000000000Z" />
                <EventRecordID>5721</EventRecordID>
                <Channel>Application</Channel>
                <Computer>hp-PC</Computer>
                <Security />
              </System>
              <EventData>
                <Data>Photoshop.exe</Data>
                <Data>18.1.1.252</Data>
                <Data>58737f6a</Data>
                <Data>c0000005</Data>
                <Data>000000000ae17b88</Data>
                <Data>174c</Data>
                <Data>01d2dfdef8ecd4d5</Data>
                <Data>C:\Program Files\Adobe\Adobe Photoshop CC 2017\Photoshop.exe</Data>
                <Data>5b865678-4bd2-11e7-a54e-b4b676fa55e5</Data>
              </EventData>
            </Event>
