2 Replies Latest reply on May 21, 2017 3:11 PM by shilpakk
    File download, name and number
    shilpakk
      Hi!
      When I download a file, it appears  with certain number in acrobat reader. for example, file name as 41**, 5678, 1267 etc. Without file name, Its diificult to find a file and its also difficult to rename each file. Any help in this matter will be appreciated.
      Thank you.
        • 1. Re: File download, name and number
          Adorobat Adobe Employee
          Hi shilpakk,
          Could you please confirm the Acrobat Reader version installed on the device?
          To do that, launch the app>tap 3 vertical dots in the top right corner>Help
          Tap three vertical dots again and select About Adobe Acrobat
          Android OS version installed on the device?
          Tap Settings from the device home screen>About Phone>Device Information
          Does the file name appear the same as you mentioned in your example in the "Downloads folder" as well?
          • 2. Re: File download, name and number
            shilpakk Level 1
            Hey Acrobat Reader version is 17.1 and andriod version is 6.0.1
            The file name is same on "downloads folder" and Acrobat reader. Mostly the files, that are numbered file names on Reader, are not on download folder. Though they were downloaded and not deleted.
            Thank you for your response.
