2 Replies Latest reply on Feb 14, 2017 7:57 AM by roba75280674
    Use script and Grep to creat unique hyperlinks
    roba75280674 Level 1
      I'm new to scripting and was wondering if it would be possible to creat unique hyperlinks based on a grep?
      I have an indesign file with lots of six digit item numbers. Can I grep for \d{6} and create a hyperlink like google.com/123456 with that number as the anchor text? The digits are unique but the base URL is the same throughout (In this example google.com/).
      I was trying with AppleScript but if the number repeated then the script failed.
      Any help is is much appreciated.
      Thank you
        • 1. Re: Use script and Greg to creat unique hyperlinks
          Liphou Level 2
          Bonjour roba,
          Regarde -> Create hyperlinks with script, without big increases to size and processing reqs of resulting PDFs?
          voici :
          #target "indesign-12.064"  // CC2017
          app.findGrepPreferences = app.changeGrepPreferences = null;
          var doc = app.activeDocument;
          app.findGrepPreferences.findWhat = '\\d{6}';
          var objs = doc.findGrep();
          for (var i = 0; i < objs.length; i++) {
              var currTarget  = objs[i];
              var lnkDest = doc.hyperlinkURLDestinations.add("http://www.indesignjs.de/extendscriptAPI/indesign-latest/#Application.html");
              var lnkSrc = doc.hyperlinkTextSources.add(currTarget);
              var lnk = doc.hyperlinks.add(lnkSrc, lnkDest);
          alert('Processed '+objs.length+' hyperlinks');
          cet exemple est tiré du lien cité plus au il fonction.
          • 2. Re: Use script and Grep to creat unique hyperlinks
            I think I solved it with this:
            app.findGrepPreferences.findWhat = "\\d{6}-.{2}";
            var myFound1 = myDoc.findGrep();
            count = 0
            for(k=0; k<myFound1.length; k++)
            var myFind = myFound1[k];
            var myFound = (myFound1[k].contents);
            var classNo = myFound.split("-");
            var myHyperlinkSource = app.activeDocument.hyperlinkTextSources.add(myFound1[k])
            var myHyperlinkURLDestination = app.activeDocument.hyperlinkURLDestinations.add("https://www.apexprd.org/scripts/webtrac.wsc/Wbsearch.html?xxmod=AR&xxactivitynumber="+classNo[0])
            var myHyperlink = app.activeDocument.hyperlinks.add(myHyperlinkSource, myHyperlinkURLDestination, {name: myFound1[k].contents+count++})
            alert(count/2 + " occurencces is changed")
