4 Replies Latest reply on Feb 15, 2017 1:05 PM by cbishop01
    Is there a way to lock postition and still beable to paste Pictures in text frames?
    cbishop01 Level 2
      Hello all,
      Is there a way to lock the position of a text frame but still be able to paste Pictures/Bar codes/ anything inside it? I have the below script placing the Text frame where i want it.  But i want it to stay in that position.  So no one can accidentally move or manipulate the text frame (Other than paste Graphics inside)
          #targetengine "AutoStartScript"
       app.addEventListener( "beforeSave" , dotFOnPageOne );
       app.addEventListener( "beforeSave", doMLyer );
      //>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>Move to layer<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<\\
          function doMLyer(){
              layers = app.documents[0].layers;
          if (layers.item('OUR Barcode').isValid) {
            layers.item('OUR Barcode').move (LocationOptions.AT_BEGINNING);
      //>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>CREATE NEW layer FOR SAVE CHANGES<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<\\
          function doLyer(){
              var _d = app.documents[0];
              var _allStories = _d.stories;
              for(var n=_allStories.length-1;n>=0;n--){
              var _storyAllTextFrames = _allStories[n].textContainers;
                  for(var m=_storyAllTextFrames.length-1;m>=0;m--){
                      //If the contents of a text frame is an empty string:
       if(_storyAllTextFrames[m].contents === ""){
       _storyAllTextFrames[m].select();
       //Convert frame to "Unassigned":
                /*      try{
       app.scriptMenuActions.itemByID(11297).invoke();
       }catch(e){};  */
              //Trick to deselect the last selection
              //Add a new textFrame, select and remove it:
              var _tempTextFrame = _d.textFrames.add();
       _tempTextFrame.select();
       _tempTextFrame.remove();
      //>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>NEW layer Color Settings<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<\\
          function addlayer(doc, name){
              try{
                  var layer = doc.layers.itemByName(name);
                  if(layer && layer.isValid) {
       return layer;
                      } else {
                  var mylayer = doc.layers.add();
       mylayer.name = name;
       mylayer.layerColor = [100,50,100]
                      return mylayer;
            } catch(e) {
      //>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>CREATE TEXT FRAME FOR SAVE INFO<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<\\
          function addTextF(doc, layer, name){
              var myBlendingSettings = { blendMode : BlendMode.NORMAL };
              var myTransparencySettings = { blendingSettings : myBlendingSettings };
              var tF = doc.textFrames.itemByName(name);
              if(tF && tF.isValid) {
       tF.remove();
              var origUnit = app.scriptPreferences.measurementUnit;
       app.scriptPreferences.measurementUnit = MeasurementUnits.INCHES;
              tF = doc.textFrames.add(layer, LocationOptions.UNKNOWN, {name: name, fillColor :"None", fillTint: 0, transparencySettings : myTransparencySettings,
                  geometricBounds: ['.65in','.062in','.23in','-.066'] });
       app.scriptPreferences.measurementUnit = origUnit;
                    return tF;
      //>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>MOVE TEXT FRAME TO layer<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<\\
          function dotFOnPageOne(event){
              var doc = event.target;
              if(!(doc && doc.constructor.name == "Document")) {
       return;
              var mylayer = addlayer(doc, "OUR Barcode");
              var tF = addTextF(doc, mylayer, "OUR Barcode");
      Thanks for any help.
